Hi all,
I wonder if anyone has had this issue...
The 2006 S60 with 106K miles:
- At low speed in parking lot such as 5 mph, I hear ratting noise like loose rocks.
- At highway speed, no noise.
- So I jacked up the rear end and supported with jack stands.
- Rear Shocks look fine, no broken upper mounts.
- Sway bar bushings and end links seemed fine.
- I got underneath and tapped the Left Rear side of the Fuel Tank (directly below where the LR passenger sits)...I heard rattling noise like rocks inside the fuel tank or rocks above the fuel tank.
- Think about a plastic tray holding 2-3 rocks and you tap it from below...this is the sound I heard.
- Fuel tank is 3/4 full.
- Short of removing the fuel tank (which I don't have any desire to) to check what is above it or inside it.
- My "lazy" ming tells me to live with it. But I want to ask the group if you guys ever had this issue before?
2006 S60 rattle noise Left Rear Fuel Tank area...
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
its a good time to get a endoscope/boroscope for smartphone, $40 amazon, get one with the light and mirror.
if theres anything up there you'll find it, might just be acorns from squirrels.
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 132 times
- Been thanked: 126 times
I get a weird rattle after filling up the S60 when pulling away from gas station. Living with it after 5 years.
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- BlackBart
- Has thanked: 967 times
- Been thanked: 923 times
It could be the heat shields around the exhaust near the tank. There are fasteners that can vibrate loose. Makes rattle noises.
- Been thanked: 4071 times
I had a horrible rattle in the p80 suspension which was a loose spring cup on the left rear strut. Is there an analogous part in the p2 suspension?
- 2298 Views
Last post by GazmorGuri75
- 1818 Views
Last post by wackenhut
- 11 Replies
- 6451 Views
Last post by lostmyVcardXC
- 1577 Views
Last post by BlackBart
- 11 Replies
- 2355 Views
