1999 S70 GLT. I started the car this morning and it fired up, but then abruptly stopped. That has happened before and I just crank it again and go. but the battery was drained due to parking lights left on, so I charged the battery to 100%. But now I get a completely different sound during crank it almost sounds like no compression. The timing belt was done 30k ago and seems to be intact. The car turns over however it sounds completely different. heres what i have done so far.
No codes on on my scan tool
pulled the starter an had it tested, pass all tests 3 times.
battery is newer and had a full charge. My hand tester shows good voltage and solid cranking amps on the dial.
any ideas on where to go from here?
1999 S70 GLT - starting issue
- Grantkat
- Year and Model: 1999 s70 GLT
- Has thanked: 59 times
- Been thanked: 54 times
1999 S70 GLT ~193k
2014D VIDA/DICE
2007 Jeep Wrangler Unlimited ~ 315K
2008 Lincoln MKX ~130k
2008 Toyota Sequoia ~ 252k
Powered by coffee, stripped bolts, and questionable decisions.
2014D VIDA/DICE
- gmh
- Year and Model: 2016 XC60 T5
- Has thanked: 28 times
- Been thanked: 22 times
1) Cold weather
2) started but ran only a short time
3) sounds like no compression when it turns over
Search "lawn mower syndrome" in this forum.
Gary
1969 145S (1987-91)
1973 145E (1989-90)
1981 245 (1990-2001)
1981 244 (1991-2002)
1989 760 Turbo Wagon (1999-2011)
1994 850 Turbo Wagon (2002-2013) burnt valve
2001 V70 2.4T (2009-2017) sold
1997 850 R Wagon (2013-2025) sold to Matthew
2014 XC60 T6 (2017-present)
2016 XC60 T5 (2024-present)
1969 145S (1987-91)
1973 145E (1989-90)
It probably over flooded with fuel on the cold start, which causes “ lawn mower syndrome”
No damage
No damage
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
Anyone know if this has the same "evil" anti-theft in the key as the '99 V70 XC? If so, scan it with VIDA and make sure it sees and authenticates the key. If it doesn't, it could do that as well.
- Grantkat
Thank you for the input everyone. The car is up and running. it took some doing but i was successful. I removed the plugs, cleaned them and then let the cylinders air out over night. small dab of oil in each cylinder and the car turned over and started but immediately died and went back to not starting. Did it again and after some gentle coaxing (experience from my days with carbureted cars flooding), i got it started, kept it at about 1500-2000 rpm for a bit until I saw the temp guage start moving and then it was fine.
1999 S70 GLT ~193k
2014D VIDA/DICE
2014D VIDA/DICE
- 19 Replies
- 7398 Views
- 19 Replies
- 2994 Views
Last post by z80
- 2426 Views
Last post by jmorman
- 672 Views
Last post by BlackyChan91
- 12 Replies
- 2299 Views
Last post by erikv11
