I have a very recent issue on starting. When i start the car fires right up however instantly wants to stall. If i dont give it gas it stalls immediately (cause for me recent lawnmower syndrome). However if i stay on the gas for about 1 min (sometimes less) it will idle normally and run fine. once warmed up it will be fine to restart.
I have done some research on here and have seen coolant sensor, MAF and fuel relay however the descriptions of their symptoms arent quite like mine.
likely cause and advice please?
99 S70 GLT Engine B5254T [Vacuum leaks, hoses, Snorkel] Topic is solved
- Grantkat
- Year and Model: 1999 s70 GLT
- Has thanked: 59 times
- Been thanked: 54 times
1999 S70 GLT ~193k
2014D VIDA/DICE
2007 Jeep Wrangler Unlimited ~ 315K
2008 Lincoln MKX ~130k
2008 Toyota Sequoia ~ 252k
Powered by coffee, stripped bolts, and questionable decisions.
2014D VIDA/DICE
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
No codes?
I'd start with coolant sensor and/or the FP relay if the issue started when it got colder.
- Grantkat
HI Chuck NO CEL light no codes.
New development - tonight after coming home from work (40 minute drive at mostly 60 MPH +) I stopped at the store (10-15 minutes stop). When i came back out and started the car again it seemed to want to stall but then after a few gentle revs it was fine. before exiting the parking lot, the RPM dropped from 1100ish to 600ish and the car started "chugging". here is my best description of what followed. for about 100 yards when i push on the accelerator it would barely go followed by a "chugging" where it would move forward somewhat then back to giving gas and it barely moving. The engine was making a "dieseling" sound. I was working the pedal up and down and it was sort of chugging and lurching somewhat as if sometimes the pedal was working and others it wasnt. Then all the sudden the engine kicked into normal operation, the car jumped, sped off and I took off down the road like nothing happened. Upon getting home there was a hint of that sort of rich dieseling smell from the exhaust after turing the car off
1999 S70 GLT ~193k
2014D VIDA/DICE
2014D VIDA/DICE
- Grantkat
again - no codes
1999 S70 GLT ~193k
2014D VIDA/DICE
2014D VIDA/DICE
- Chuck W
The stumble to all of a sudden running fine leads me to think it could be a fuel delivery issue. (How old is the pump?)
How much gas is in the tank? I would check fuel pressure as well.
I had a car that would do the random stumbles and then clear up. They issue was a shoddy FP replacement by a PO and the feed hose out of the pump inside the tank was barely hanging on. (See PIC).
The fuel pressure would randomly drop due to the open connection, and cause it to run poorly. It was obviously less of a problem the more fuel that was in the tank.
The relays tend to be more of a hard start when cold (at least in my experience) and not so much of a running like crap. They're always a possibility though.
- Grantkat
Fuel - tank nearly full.
Pump - unknown fuel pump is a PO and purchased as is about 18 months ago.
I will test the relay and see what gives.
whats a good way to test fuel pressure? there is a Schrader valve at the end of the fuel rail
1999 S70 GLT ~193k
2014D VIDA/DICE
2014D VIDA/DICE
- Chuck W
That Schrader is the location to test.
- Has thanked: 311 times
- Been thanked: 817 times
You can use a cheap-o tire pressure gauge on that Schrader valve. The gas will ruin the gauge but give a reliable, approximate reading. Or spring for a proper fuel pressure gauge setup.
- Grantkat
I will rent a fuel gauge set up and test the fuel pressure.
Another question - any idea about why the engine was chugging and "dieseling". That seems beyond a fuel delivery issue?
1999 S70 GLT ~193k
2014D VIDA/DICE
2014D VIDA/DICE
- Caesium
- Year and Model: 1999 V70 R AWD
- Has thanked: 13 times
- Been thanked: 9 times
As you mentioned the throttle pedal not being responsive during one of the times it was acting up, I'd get a sweep test done of the electronic throttle body if that hasn't already been serviced or replaced with an updated unit.
In the Garage
Viveka / 1996 850 N/A / Polar White + Oak / 154,9xx /
1999 V70 R AWD / Signal Red + Graphite / 171,8xx /
Previously Owned
Sada / 2011 C30 T5 M66 / Silver Metallic + Off Black / 129,7xx /
Blixt / 1996 855 R / Polar White + Dark Gray / 216,9xx /
Previously Owned
- 834 Views
- 1077 Views
Last post by Oly850
- 831 Views
Last post by befarrer
- 1191 Views
Last post by bmdubya1198
- 1285 Views
Last post by brunocerous
