I started thinking of Essential tools for DIY Volvo care. The tools you need to consider buying first if you want to do some things to keep you Modern Volvo running.
My proposed list:
1. Volt/Ohm meter
2. Battery Charger
3. Code reader
4. Basic metric tools
5. Magnetic reach tool
6. Claw reach tool.
7. Oil filter wrench
Please add and discuss.
- Has thanked: 987 times
- Been thanked: 1075 times
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
I have a tool problem,.
This is a partial list of tools I found essential.
nothing from HF.
Critical small LED flashlight, $10
LED lithium rechargeable headband lamp. $12
More lights.
4lb persuader.
Blue wrench, or yellow.
Milwaukee lithium stubby impact and power ratchet wrench. Sawzall, Hackzall, dremel with carbide disks, angle grinder.
7 gal compressor for tires and an air hammer.
goop hand cleaner
Automotive voltmeter. $35
Stethoscope $12
fox and hound elec circuit tracer $25
Quality flare wrench set $13
1/2" breaker bar.
Torque wrench.
Mig welder for broken bolts. Yes you will.
vida set up.
elm 327 obd code reader for my phone, I leave it plugged in the obd port 24/7.
spring compressors for suspension work.
Shallow 10mm universale socket for that intake manifold bolt, 1/4" drive. (thats why you'll need 12" x 1/4" extention.
https://www.amazon.com/TEKTON-Drive-Uni ... r=8-6&th=1
#4 basic meric tools, all of em and more. I buy all mine from amazon, better than HF.
deep and shallow impact socket set, full set of metric wrenches,
Extentions, wobble drive. short and long 1/2" , 3/8th and 1/4 extentions.
3/8 drive Torx , get short and extended lengths, impact quality.
Extended length aviation wrenches (brake and suspension work)
https://www.amazon.com/HORUSDY-7-Piece- ... 175&sr=8-7
nothing from HF.
More lights.
4lb persuader.
goop hand cleaner
Stethoscope $12
1/2" breaker bar.
Torque wrench.
vida set up.
- Krons
- Has thanked: 198 times
- Been thanked: 215 times
Great search skills at https://www.matthewsvolvosite.com/forums
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
I completely agree, but I wanted to start a beginners list of things to buy first.jonesg wrote: 11 Jan 2025, 12:31 I have a tool problem,.
nothing from HF.
More lights.
4lb persuader.
goop hand cleaner
Stethoscope $12
1/2" breaker bar.
Torque wrench.
vida set up.
- jonesg
its a good start, i didn't include my 2 post lift or tire changer.
But I would go for ramps and jackstands early.
I spend thousands on the workshop but save at least double the cost of tools by DIY.
You can get a really nice set of professional grade harbor freight tools for three hours worth of mechanic’s labour.
- Has thanked: 2199 times
Also a really essential tool for working on Volvos, is patience!! When for the 300th+ time you go to do what should be a simple job made difficult as some engineer decided to use one of the bolts to mount 10 other things on that must be removed first, then you have made the grade! I have to say I lost the patience part a while ago somewhere at Pick and Pull. Must have left in in a car..........!
- Has thanked: 2856 times
- Been thanked: 1332 times
Liquid Wrench
any metric ratchet set
any metric wrench set
a few screwdrivers
gloves
That's how I started
a few screwdrivers
gloves
Hmmm. That escalated quickly.Mig welder for broken bolts. Yes you will.
Lets define basic care as all belts, fluids, and things in the repair manual for 5000, 10000, 30000 mile intervals.
Good set of wood or plastic car ramps for oil changes
My undefined, unclear idea was a minimum tool set to start with. Maybe just a few tools for testing and oil change. Some people will find they are overwhelmed and lack patience to do any mechanic work at all. Others will grow their tool set as they grow their skill.
