Hi All,
This is a bit of a long shot but I am looking for a Radio code for my 1998 Volvo V70R.
The radio details are as follows:
Radio Model: 3533788-4969 (9812)
(3854800)
Radio S/N: AL E51A W 03 17790 (M 8 03 17790)
Man.Date - 1998
Things i've already tried:
Contacted local volvo suppliers - they provided code based on my cars vin: 2141, also tried permutations of this - no luck
Main suspicion: Not original radio head, or code has been changed manually - they suggested to bring it to Volvo Service and try to decode it there.
Any help would be greatly appreciated,
Thanks,
Victor
Volvo Radio Code - 1998 Volvo V70R (SC-900)
Biktop2024
- Year and Model: 1998 Volvo V70R
- Been thanked: 4063 times
You will need Volvo to get that with the radio in hand, it’s very common for them to be swapped
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
In the States this works - but the first try here may get the same answer already given:
https://volvo.custhelp.com/app/answers/ ... radio-code
But I recall being able to give them the unit serial number and they came up with a good code.
And local dealership parts departments here are sometimes pretty cooperative, especially since these radios aren't much-sought after items
amongst thieves these days.
- Has thanked: 2196 times
- Been thanked: 1850 times
They can find the unit code from the serial number of the unit. What the dealers do initially is check the vehicle details from the Vin# and then give you the code from the information there. That assumes the unit fitted to your car is the original. I've had this several times. I've pulled units from the junkyard over the years and had my local dealer find the number from the numbers stamped into the side of the case.
Good Luck!
Good Luck!
Biktop2024
Thank you all for the replies.
I reached out to FRF Volvo Swansea, they were able to track the serial number of the radio and provide a working code!
It lives!
It lives!
Glad to hear you got the code at last!!
- 11 Replies
- 10321 Views
Last post by JRL
- 1429 Views
Last post by manovlov
- 11 Replies
- 107526 Views
Last post by BEJinFbk
- 1275 Views
- 1085 Views
Last post by theWIFES_S70
