Volvo Sunroof - 1998 Volvo V70R (Volvo Glass Panel 9152097)
Biktop2024
Year and Model: 1998 Volvo V70R
Post by Biktop2024 »
Hi all.
I am looking for a Volvo Glass Panel (Part #: 9152097) around Europe, new or used, before having to take mine off and doing some DIY repair.
Any help would be greatly appreciated. Sifted through the entire web to find the part that delivers, no luck yet.
Thanks.
Has thanked: 2210 times
Been thanked: 1852 times
Don't believe it is unique to the R. I have a 2000 R and it is the same as a base model with sunroof. I think even the 850 will fit. Might want to confirm that though. Can't find it on a drawing and I have limited access to internet. I'll look again in a couple of days when internet is hopefully fixed! I you go used, as you are probably aware, check for corrosion on the frame of the glass before paying up!
Good Luck!
wizechatmgr
Has thanked: 45 times
Been thanked: 129 times
Post by wizechatmgr »
If you're having a leak, I found that the problem I had was the rubber seal to glass physical interface. Some silicone in there did the trick.
2023 Lexus RZ450e -66k
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 115 times
Post by Goupil »
Yes any P80 V70 sunroof will fit, I bought a cheap entire sunroof assembly to use the glass while I was fixing mine. Checked people breaking cars around you ? That's how I got mine, paid like 40€ for the whole thing a few years ago.
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
