2006 XC70 LTFT problems (ECM212C and ECM21EC) Topic is solved
ortho stice
Year and Model: 2006 XC70
Been thanked: 5 times
Post by ortho stice »
This thread is about a 2006 I picked up for very little money because of a persistent check engine light. The only codes in VIDA are for long-term fuel trims being high, ECM212C and ECM21EC. The car had trouble holding idle when I bought it. I put a spare ETA on and found the original throttle horrifically dirty. This solved the idle stumble but the codes persist (unsurprisingly).
The only other thing I notice is the MAF reading at idle hovers around 9 kg/h (8.5-9.5) which I've read is low for these cars. The previous owner put a new MAF in (it certainly looks new) but I don't know from what manufacturer and the OEM MAF did not come with the car. Previous owner claims the entire intake was smoke-tested and the plastic intake pipe between airbox and turbo was replaced (it's an obviously new piece). Long term trims seem normal based on the current data, the frozen state reading when the code initially came up was at 19.5% at like half throttle around 3k rpm (I think I was accelerating). Fuel pressure is dead on 400kPa and the pump's at like 35% duty cycle at idle with half a tank. Some searching around other forums suggests others with these codes typically experience terrible fuel economy, but I'm showing 19 average on the instrument cluster and calculated 23 on a recent long highway drive.
Any thoughts? I'm used to LH2.4 and have never messed with a P2 car until now. Picture of the offending car at the top of my unplowed driveway which it glided up without any problems:
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
Replace both oxygen sensors. Their life span is 100k miles, as Bosch says (who makes them).
ortho stice
That's definitely on the agenda and I can see how that could impact things. Any reason to worry about the low indicated flow through the MAF at idle?
vtl
Post by vtl »
ortho stice wrote: 10 Feb 2025, 08:31 That's definitely on the agenda and I can see how that could impact things. Any reason to worry about the low indicated flow through the MAF at idle?
Vacuum leak. Smoke the intake. Pay extra attention to the vicinity of PTC (PCV long heated pipe/hose ends there by the turbo).
What part number is on MAF. Should be Volvo original or Bosch
https://www.fcpeuro.com/products/volvo- ... 0-31342414
https://www.fcpeuro.com/products/volvo- ... 0280218088 Check the part number.
ortho stice
A smoke test will have to wait for now; I do not have the equipment. The replacement MAF they put on is an NTK brand (one of the cheaper options on rockauto). Another interesting element is that I took the airbox lid off to look at the MAF housing and element and there is organic debris sucked against the screen of the MAF housing. The air filter is brand new and the airbox is clean, but I wonder if something happened there that wrecked the first MAF, ie rodents or something.
I watched my O2 sensor values in VIDA after a quick drive. They seem to respond the way I'd expect; stabbing the throttle in neutral spikes the front way up and the rear voltage drops in response. I'll probably still replace them since they are unknown age on a 181k mile car.
Has thanked: 2215 times
Been thanked: 1853 times
Not sure how stuff got passed the filter unless the car sat for a long time and mice managed to chew through the air filter.
If there is debris up there and the repair shop did not mention an issue, I would suggest it may have been in the lower section and they did not clean the air box out when replacing the MAF. Possibly they removed the top and bottom of the box as well as the filter and then re-assembled and crap got up there. I would suggest trying to vacuum it out as best you can.
If that is what happened that is careless work by the repair shop.
It will be interesting to see how the aftermarket NTK MAF works out. If you plan keeping the car, I would suggest seeing if you can either pull or find a used OE MAF and keep it on the shelf as a back up should this one fails early.
Also let us know if/when you replace the O2 sensors how that works out.
Good Luck!
ortho stice
This weekend I replaced the radiator as it appeared to be weeping from the driver's side end-tank and I had been experiencing coolant loss every 500-600 miles. I ordered the Volvo OEM radiator because I had read about the aftermarket ones not having the reinforced hose barbs. Earlier this week the rate of coolant loss accelerated rapidly; the low coolant light was coming on after 20 minutes of driving. When I took off the upper radiator hose I found that it was loose! It was loose because someone had installed one of the aftermarket radiators and torqued down hard on the hose clamp which had totally deformed the hose barb.
Anyway I tell this story because of course I took the airbox out and found that the clamp holding the inlet pipe to the MAF was completely loose. I ran out of time tonight, but I wonder if unmetered air was getting pulled in from there. I disconnected the battery when I did the radiator, just in case, so I'm starting from a blank slate with codes.
ortho stice
Okay; I raided an '06 S80 2.5T for some parts today at the U-Pull. First of all; I pulled a clearly aftermarket MAF and housing off the car and put it on my XC70. The housing that was on the car was even more clogged than it had appeared when I first looked at it in the airbox, it had dead bugs and other debris embedded in the grid. Anyway my idle MAF flow is now 11.9-12.2 kg/h so I'm calling that resolved. I also grabbed a PEM as a spare and some seat trim.
Before I swapped the MAF, the LTFT code had come back. Here's the initial state data I screenshotted:
I honestly don't even know what to make of that. Codes are cleared for now so I'll see what comes up, if anything.
Has thanked: 1613 times
Been thanked: 4078 times
I would guess those 99% fuel trim numbers are spurious data.
The 23% total trim is pointing to vacuum leaks or unmetered air.
vtl
Post by vtl »
abscate wrote: 20 Feb 2025, 02:33 I would guess those 99% fuel trim numbers are spurious data.
99% is for Bank2, which I-5 apparently does not have. STFT 3% and LTFT 20% was definitely a problem. Either a leak or bad MAF reading.
