2006 Volvo V70, Center Console, AC light driver side + safety lock/ alarm sensors button light off
LongNoseElk
Year and Model: 2006 V70
Has thanked: 134 times
Been thanked: 25 times
Post by LongNoseElk »
Hello Volvo owners and fans,
the right side of the AC temperature selector illumination on the driver side of my 2006 Volvo V70 is off (already was when I bought it, but I didn't regard it as a flaw as the AC is working fine. I've already found a wiring manual for the Volvo, which will hopefully give some insight to which fuse and wire is connected etc.
Another thing is the illumination of the safety lock button is off, too. So I really don't know if the button is a dummy nor if the safety is activated or not.
Now, before I get my crowbar to open the center console (just kidding ), does anybody of you has a tutorial and or information about how to open the CC respectively what could be the issue?
2006 Volvo V70 black
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
I don't know but if you go in there and start unplugging things be sure to unhook the neg battery terminal or risk getting an SRS fault code.
if it were mine...I wouldn't even bother.
Has thanked: 2197 times
Been thanked: 1851 times
Does your sunroof work? Could be the alarm siren is bad.
Not had one of those center panels apart (yet) for a P2 car to see if there are bulbs or soldered in LED's for lighting that may have burnt out. Most buttons have their lighting in built. If you depress the button, I'm assuming it doesn't light up?
LongNoseElk
scot850 wrote: 20 Feb 2025, 08:34 Does your sunroof work? Could be the alarm siren is bad.
Sunroof works like a charm. And I'm not sure if the model came with an alarm system... well, the owners manual of this model provides instructions on how to use / test this safety lock function, so I'll give it a try (second person required to lock the car from the outside while another stays inside... you know the drill).
I'd assume the same as you: LEDS to illuminate, but then I wonder why using 2, one for the left and on for the right side of the selector only?
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 117 times
Been thanked: 271 times
Post by Blacklab467 »
The buttons, fan rheostat and alarm button are LED's soldered in. The backlighting of the Panel use T4.2 bulbs and are easily replaced. Look up a video for radio removal to get instructions on how to remove all those components for repair or inspection, it's pretty easy and you can have all that stuff out and on your bench in about 15 minutes.
2003 XC 70 (sold)
Has thanked: 1609 times
Been thanked: 4064 times
Is that safety lock feature designed to prevent kids ftom getting locked in?
