2006 XC90 2.5t - PCV have any rubber seals?
SchalkwjkM4
- Year and Model: 2007 Xc90 2.5t
- Has thanked: 1 time
Does PCV valve oil trap have any rubber seals that needs to be replaced...what would cause to oil leak from it...how is it placed and attached under intake manifold(hooked/bolted/screwed)? This is because it's leaking oil and i think i need to replace it. Secondly how is radiator cooling fan 12v direct test performed, where do i hook the signal wire if i perform the test?...thanks
