My CAT fell off! - 2007 Volvo XC70
cmayo1
Year and Model: 2007 XC70
Has thanked: 51 times
Been thanked: 9 times
Post by cmayo1 »
So, I went to the post office to pick up a package. Went inside, gave my autograph, and was ready to head to work. Got outside and saw my tail pipe laying on the ground... great. The whole system has been leaking for a while, and I've been holding off on replacing it. I thought "maybe I can just hitch it back on and get to work". I got on the ground ( while it's snowing :D ) and looked, only to see the catalytic converter hanging off too.
Free custom exhaust!
I'm having the whole thing done over, including the CAT, but my question is two fold:
1. Has anyone run into code issues with an aftermarket CAT? I can't afford an OEM one
2. Has anyone run into code issues with aftermarket O2 sensors?
Thank you,
Christopher
2007 Volvo XC70
free time ≠ money
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
*checks location>>>>>New Hampshire. Yep.
cmayo1
Post by cmayo1 »
We really should change our State Mineral to rust
2007 Volvo XC70
free time ≠ money
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
cmayo1 wrote: 27 Feb 2025, 13:15 So, I went to the post office to pick up a package. Went inside, gave my autograph, and was ready to head to work. Got outside and saw my tail pipe laying on the ground... great. The whole system has been leaking for a while, and I've been holding off on replacing it. I thought "maybe I can just hitch it back on and get to work". I got on the ground ( while it's snowing :D ) and looked, only to see the catalytic converter hanging off too.
Thank you,
Christopher
yes and yes both questions.
I don't thinkl you can even get an OEM cat.
Get it welded.
cmayo1
Post by cmayo1 »
jonesg wrote: 27 Feb 2025, 20:36 yes and yes both questions.
Get it welded.
Why do I need to weld it? What am I welding?
2007 Volvo XC70
free time ≠ money
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
Upstream sensor - OE or matching Bosch only. Can look up part number at FCP.
Downstream sensor - get yourself a Hiltone tune, it disables CAT efficiency check (no codes) :) Otherwise you will probably get codes with ceramic Magnaflow or whatever ceramic CAT you've got.
Do you still have your old cat? Don't get rid of it yet.
Has thanked: 2199 times
Been thanked: 1852 times
Volvo cats are still available and really reasonable up here at ONLY $3000 CDN!!? Yikes, what are they made of? Pure gold?
I replaced the crappy Toyota exhaust manifolds and Y Pipe on my V8 4Runner with a stainless steel tubular aftermarket unit and high flow cats (there are 2 of those). To stop them tripping the O2 sensors, they fitted a spacer bung welded to the O2 sensor hole to move them out of the flow a little which prevents the O2 sensors from setting off the check light. Not sure if that would work on the Volvo but might. I've had no issues other than a more efficient system with more power than OE.
vtl
Post by vtl »
scot850 wrote: 28 Feb 2025, 08:11 Volvo cats are still available and really reasonable up here at ONLY $3000 CDN!!? Yikes, what are they made of? Pure gold?
Pure gold would run them cheaper. OE cat is full metal (precious metal).
jonesg
Post by jonesg »
cmayo1 wrote: 28 Feb 2025, 05:25
Get it welded.
the flex pipe is welded to the cat, the aft cat flange joint is just bolted and can be fixed or welded.
I'm in Maine and couldn't get a suitable downpipe/cat shipped here, autozone wanted $900 ,
so I bought a welder and welded in a new flex pipe section.
If the cat was hanging loose .. that can damage the flex pipe.
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
Re: the bung. Used that trick on an old MPV you can buy a DORMAN spark plug non fouler and it fits perfectly.
04s60 2.4
04xc70 2.5t
