Door closed sensor failed? / continuous chime
beewstew
Year and Model: 2004 xc70
Has thanked: 34 times
Been thanked: 5 times
Post by beewstew »
Working on a 3rd hand 2004 xc70.
When all doors are closed and the car is running, the red ! on the dash lights up, the message panel reads "the door is open dummy!", and the 1Hz indicator chime is continuous (for 10 minutes or so of driving).
I can block the chime out with the radio, but the interior lights stay on and drain the battery.
The best way to fix this is probably a junkyard driver door lock module? Is that where the door closed sensor lives?
I haven't spend the money for an aliexpress vida/dice module yet. Is that the proper way to diagnose this sort of electrical problem?
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
One of two things may have failed.
A wire from door to the wire harness goes through the door jamb may be pinched or broken.
The door module may have a failed sensor or wiring fault.
Replacement door modules may need to match your old module to sync with the computer.
beewstew
Post by beewstew »
@volvolugnut thanks! I'm new to this. What do you mean by "Replacement door modules may need to match your old module"
Does it have to come from a 2004? From a 2004 xc70?
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
He means the module part number has to match exactly the one in your car. You would have to pull yours first to verify.
I would start by disconnecting the wiring harness at the door (it's in a corrugated rubber boot looking thing) and spraying it with a contact/electronics cleaner on both the male and female plug and plug/unplug it a few times to clean up the connections. It may just be a tarnished contact on either side.
04s60 2.4
04xc70 2.5t
firstv70volvo
Year and Model: V70 T5 2001
Has thanked: 52 times
Been thanked: 123 times
Post by firstv70volvo »
beewstew wrote: 12 Mar 2025, 06:55 Working on a 3rd hand 2004 xc70.
Within the door lock/latch module there are two microswitches, one for the door open/close status and one for the door lock/unlock status. These switches do create problems and you can't access them to clean or repair them. A used or new door module will likely be needed for the fix but it can also be an open wire but this is a less probable cause for this problem, it's usually a switch in the module.
