Hello,
Yesterday, I drove the car for 20mins in the morning to get to my uni and after ~3 or so hours, when i went to leave the car wouldn't start. I crancked it 3-4 times with no avail, let it sit for a minute or so, and then cranked it again and it started with an engine light on. On my way back home i noticed everything was ok(smooth driving and idling) and when i went home i plugged in VOL-FCR and got this:
EFI-314 Camshaft position sensor signal.
I reseted the code and today i did around 4 trips 20min each and no light. I was wondering if this means that the sensor is going bad. Is there a chance my sparkplugs are the problem since when i run LPG on low revs its a bit rough after getting hot.
Please advice on how should I procceed.
Thanks in advance.
Camshaft Position Sensor Signal Volvo S70 T5 97'
- Has thanked: 2197 times
- Been thanked: 1851 times
Sorry, can't help with the LPG side of things as we don't have them over here. Simply answer is it is possible the cam sensor is failing. However there are more things than that that could be an issue and the can sensor code may just be what the final issue was.
The areas I would check are:
1) Fuel pump relay
2) Cam position sensor wiring and connector. make sure the cam sensor and crank sensor wires are kept as far away from the distributor as possible. If they are moved too close to the distributor it can cause the cam and crank sensor signal to be lost.
3) Check the connector for the cam sensor for corrosion.
Otherwise it is a case of waiting until it happens again, or replacing it to be sure. If it is the original it may be it is just starting to fail.
1) Fuel pump relay
perhss70
- Year and Model: s70 1997
- Has thanked: 6 times
- Been thanked: 3 times
It happened again today. I don't know if it was a good idea but I drove around 150km to my city anyway. Found a used sensor and changed it while also checking wiring. Wiring is pretty bad (the outer black plastics start to crumble) but as far as the wiring goes it seems fine. Is it viable and (relatively straight forward) to make a wiring rehaul? (I have basic electrical education) but mostly house wiring etc. Regarding the sensor
I will keep you updated
Perhs
Perhs
'97 S70 2.0T5
- 2595 Views
Last post by Luzanov345
- 2527 Views
Last post by Labone
- 2595 Views
Last post by Clemens
- 996 Views
Last post by grackel
- 4073 Views
Last post by RickHaleParker
