Does anyone have ideas on how to test a steering rack before completing the difficult installation into a car? I have a junkyard rack and would like to replace seals two other racks but would want to test them all before use.
My one idea is to have a hydraulic hose shop make extended input/output hoses by clamping long, new hoses to the cut off ends of the OEM hoses. I could then leave the rack on a bench, run the hoses into the car, power up the system, and turn the rack by hand to see it work. Problem is, the system would not be under load, not overcoming the friction of wheels on pavement. But at least it could get under pressure. What do you think?
Test a steering rack before installation?
- FireFox31
- Has thanked: 159 times
- Been thanked: 303 times
FireFox31
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
Firefox, I like your idea. You won't be able to fake the load situation, but at least having fluid circle in the rack on the bench and turnin it end to end will show if there is any major problem before installing it in the car.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- 1460 Views
Last post by bmdubya1198
- 2346 Views
Last post by SuperHerman
- 1202 Views
- 13 Replies
- 4198 Views
Last post by gswede
- 835 Views
Last post by FireFox31
