Can anyone explain this please?
Can anyone explain this please?!! The blower motor sometimes works sometimes doesn’t. It’s been removed …. It works fine when 12v applied directly. New resistor fitted. There appears to be voltage arriving at the input (black and red). Even appears to be voltage leaving the resistor. In the input plug there are also a blue and yellow wires. If they are the key (from the CCU?) how can they seem to stop it working if all the above findings are true?!!
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
elecs on the volvo are usually constant 12v feed, they turn on by completing the ground circuit.
You need a circuit diagram to see where the ground is switched. Maybe a relay on the CEM.
- firstv70volvo
- Year and Model: V70 T5 2001
- Has thanked: 52 times
- Been thanked: 123 times
If the blower motor is a DC motor with brushes and a commutator, which I think it is, then it can be the motor, the brushes wear, the surface of the commutator wear and you get an intermittent bad contact point, a dead spot and the motor doesn't start. This happens to engine starter motors and why you'll hear advice to give it a good whack to get it going.Wompe1959 wrote: 19 Mar 2025, 01:52 Can anyone explain this please?!! The blower motor sometimes works sometimes doesn’t. It’s been removed …. It works fine when 12v applied directly. New resistor fitted. There appears to be voltage arriving at the input (black and red). Even appears to be voltage leaving the resistor. In the input plug there are also a blue and yellow wires. If they are the key (from the CCU?) how can they seem to stop it working if all the above findings are true?!!
Vova585
- Has thanked: 228 times
- Been thanked: 238 times
Agree about possible wear in the motor contacts. If you already replaced resistor(was it blown? If yes, chances are that worn motor caused it). You would be better off paying for nissens or behr or PPS part and see if your issue resolved($120-200 range). You can chance it by used unit from ebay for around $40.
- DavidE7
- Year and Model: 01-07 V70, S60, XC70
- Has thanked: 67 times
- Been thanked: 93 times
if the motor stops at just the right spot where there isn't good contact from the brushes to the comutator, the motor won't run until it is bumped a little out of the bad position. (Same reason for hitting a bad starter with a hammer.) I usually slam the glovebox a couple times to get it running and then plan to replace the motor and resistor ASAP. Behr has gotten very expensive but they made the OEM parts that usually last 150,000 miles+ on my Volvos.
David E
2001 Moondust V70 2.4 293,000 miles
2001 Nautic Blue V70 2.4 231,000 miles
2004 Nautic Blue XC70 2.5T 258,000 miles
new: 2004 Black Saphire V70R 193,000 miles
2007 Titanium S60 2.5T 277,000 miles
2007 Magic Blue S60 2.5T 233,000 miles
2007 Silver V70 2.4 203,000 miles
P2 Volvos for every person in my family
- Been thanked: 4066 times
That’s a great fleet , David. Not to mention two Nautic blues….
- 546 Views
Last post by MoVolvos
- 1932 Views
Last post by manovlov
- 175 Views
- 2170 Views
Last post by Richard_TD
- 1361 Views
Last post by vjaneczko
