Brake pad overhanging rotor??
JMD77
Year and Model: 2005 S60 2.5T FWD
Post by JMD77 »
Irritating me. Doesn’t look normal. Puzzled. New EBC rotors and pads. New caliper. The rotors are the same size as factory. Calipers seem an exact match. Everything bolted up easily and is torqued to spec. Overhang seen below is approx 3/8” or so. Thoughts?
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
I agree, doesn’t seem right. If the rotor and caliper are the correct dimensions, then it’s in the pad, which makes it an easier thing to fix.
Someone sent you the wrong part number, off by a digit?
JMD77
Post by JMD77 »
Thanks. Yeah I compared the pad to the old one and they’re exact. I don’t know. I’ll measure the rotors more precisely. As far as I know there’s just 2 options on this vehicle. 286 and 300 something. I definitely do not have the bigger rotors. Perhaps some manufacturers make rotors that could be a few mm off?
I did also replace the strut and end link as well as the cv axle. I’m unsure that any of that could impact this issue. Would seem not.
Has thanked: 1610 times
Been thanked: 4068 times
Ugh. Don’t like that at all. Maybe compare rotors?
280mm and 305 mm are the p80 variants
JMD77
Post by JMD77 »
Well, finally took it back off and wouldn’t you know the mounting bracket is a diff part number and slightly “taller” that what was on there. Caliper looks identical, thought. Guess I’ll put the old bracket on and go with the new caliper. New Caliper and bracket came together, attached.
BlackBart
Post by BlackBart »
Good find.
It came with a bracket? Weird.
JMD77
Post by JMD77 »
Yeah, I put on power stops in the rear and those included brackets. Couldn’t find that brand for front so went with ultra power something or other. Also had the bracket. Identical at first glance but definitely the wrong bracket. Bolts up perfectly, just too tall
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
JMD77 wrote: 23 Mar 2025, 09:55 Yeah, I put on power stops in the rear and those included brackets. Couldn’t find that brand for front so went with ultra power something or other. Also had the bracket. Identical at first glance but definitely the wrong bracket. Bolts up perfectly, just too tall
Ultra Power with bracket may have ASSUMED the larger rotors. Stuff happens.
Has thanked: 2202 times
Been thanked: 1852 times
Maybe P2's have 3 diameters like P1's. They use the same brackets and calipers I believe with the 2 smaller diameters but the largest version has a different caliper and bracket. Now I have to go check! :lol: :lol:
Again good catch!
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
Try reinstalling an old rotor with the new pads and calipers. That should help identify the culprit.
