Car is a 2002 V70 249k miles, We have owned since 68k. Rotating the knob to adjust the wiper delay seems to make no difference although at times the delay does appear to be different. I think this always been the case since we owned the car but I only started driving it recently.
Have no idea where to start. Hardware or software? Anyone else have this problem?
Windshield wiper delay not working
Vova585
- Has thanked: 228 times
- Been thanked: 238 times
I would buy a new stock. Most likely the connector inside worn from "adjusting". Same as turn signal stock is getting worn around 170k and you can either replace with new and forget or heroically try to clean connectors and adjust. Total "parts cannon" suggestion but unless you want to remove the stock and connect ohm meter to the proper connectors(either pay for all data or look somewhere in vida for hours)and good luck finding proper values...
- ljsommar1
- Year and Model: 2002V70
- Been thanked: 8 times
I replaced the ignition lock assembly some years ago, I'm assuming it should just be removing the covers to get access, then a connector and a few screws. Any tricks?
By the way a competent parts guy at the dealership also thought it would be the stalk.
- DavidE7
- Year and Model: 01-07 V70, S60, XC70
- Has thanked: 66 times
- Been thanked: 92 times
Remove the three T25 screws from the bottom of the steering column cover. Pull off the top and bottom covers - this is tricky because of the ignition cylinder face and tilt steering wheel lever. There are two silver phillips screws at the base of the right stalk. Remove these screws and then carefully pull on the stalk perpendicular to the column. There is an electrical connector on the bottom of the stalk that automatically connects and disconnects when you pull the stalk off.
Disassembly of the stalk to get to the internal contacts is really tricky because of several hidden snaps. I gave up and got a replacement part at the junkyard because I couldn't get the snaps to unhook.
David E
2001 Moondust V70 2.4 293,000 miles
2001 Nautic Blue V70 2.4 231,000 miles
2004 Nautic Blue XC70 2.5T 258,000 miles
new: 2004 Black Saphire V70R 193,000 miles
2007 Titanium S60 2.5T 277,000 miles
2007 Magic Blue S60 2.5T 233,000 miles
2007 Silver V70 2.4 203,000 miles
P2 Volvos for every person in my family
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 132 times
- Been thanked: 126 times
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- ljsommar1
Purchased wiper unit from Erie scrapyard and installed this afternoon. It resolved the issue, 15 minute job.
Thanks for everyone's help. It will be nice to have wiper delay again.
Really love this site. It has saved me untold dollars.
- 35 Replies
- 4908 Views
Last post by MadeInJapan
- 728 Views
Last post by Cookeh
- 1317 Views
Last post by bmdubya1198
- 1843 Views
- 1467 Views
Last post by SuperHerman
