When your CV axle is made from 100% pure unobtainium, this is the last thing you want to see. Yes, this is the dreaded front right axle from an '04 V70R M66 AWD.
The only axle I could find (period) that might work is the Trakmotive VO-8041, despite unclear fitment information. I'm going to give that a try, unless someone chimes in and says I definitely should not.
The good news is that the transmission and angle gear are still in great shape (had to drop 'em to check). And the "while we're at it" list included new front subframe bushings, prop shaft front CV (torn boot), angle gear collar and seal kit, engine & transmission torque mounts all around, lower ball joints, and fluid replacements.
Appreciate everyone's crossed fingers.
04 V70R M66 AWD Front Right Axle
Is that axle a tube vs solid on the R font weight reduction? Iโve never seen an axle snap like that.
Is that awd m66 ftom Canada or is it a conversion?
We didnโt get awd m66 in the States TTBOMK
Corrected
spinard
- Year and Model: '04 V70R, '16 XC70
- Has thanked: 1 time
- Been thanked: 3 times
Wow, I've never heard that M66 AWD were not available in the US. Vehicle history shows its entire life in MA, PA, and OH. If it's a conversion I wouldn't know.abscate wrote: 13 Apr 2025, 04:06
Is that awd m66 ftom Canada or is it a conversion? We didnโt get awd m66 in the States TTBOMK
Yeah, the shaft is (was) a tube between the angle gear and the inner CV joint.
- Break Close Up.jpg (60.27 KiB) Viewed 670 times
Maybe just the xc70 didnโt come with m66?
- Has thanked: 311 times
- Been thanked: 817 times
There are/were lots of P2 R cars with M66 in the US. Both S60 and V70.
Sujsage
- Year and Model: 2004 S60R
Just wanted to confirm that the VO-8041 is a perfect fit for a passenger side M66 AWD axle, I just put one in last weekend. The inner joint is a different style but the length and position of the support bearing are the same as the old stock one.spinard wrote: 12 Apr 2025, 17:47 The only axle I could find (period) that might work is the Trakmotive VO-8041, despite unclear fitment information. I'm going to give that a try, unless someone chimes in and says I definitely should not.
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
Can't find the exact picture, but Chinese axles love to do this in high power applications:Sujsage wrote: 16 Apr 2025, 22:41 Just wanted to confirm that the VO-8041 is a perfect fit for a passenger side M66 AWD axle, I just put one in last weekend. The inner joint is a different style but the length and position of the support bearing are the same as the old stock one.
Auto-torque damping feature
- Has thanked: 2200 times
Does the S60R have the same axle as the V70R? If they do then you get both with manual trans (spaceball).
I'll keep an eye out for one. There are a couple of people selling parts from broken P2 R's in the BC area of Canada on FBM.
- 2011 Views
Last post by matthew1
- 1941 Views
Last post by darrylrobert
- 2216 Views
- 2021 Views
Last post by vtl
- 1242 Views
Last post by Richard99
