I am wondering what people use to lubricate the doors and the sunroof on their Volvo's.
For the sunroof, I imagine you would need to lubricate:
1. The hinges that raises the sunroof when you are "venting"
2. The tracks
Is there anything else, like the outside edge of the sunroof?
For the front and rear doors, would WD40 work or is there something better?
I've looked around for answers and the owner's manual only seems to say "oil". Any recommendations on brands would be great. Thanks!
Andy
Oil/lubricant for doors/sunroof (98 V70 XC)
srnkanator
- Year and Model:
WD 40 is more of a cleaner. Use it on the antenna mast. Chain oil (for bicycles) works well on most other stuff. Other may have opinions . .
slightly modded 850 T.... ;0
2010 XC60 T6 AWD
2005 S60 2.5 T
2010 XC60 T6 AWD
2005 S60 2.5 T
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
I use white grease in a spray can. No specific make as I have found them all the same.
The beauty of this is once it hits where you want it, it stays there. It doesn't run or drip and water runs off it without taking some of it away.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
VolvoBeginner
- Year and Model: 2002 S60 2.4T
White Greas in spray is The Best...
I use "3-In-One" White Lithium Grease
1994 Volvo 850 Wagon (N/A) - sold
1999 Volvo V70 (N/A)
bobsnow100
- Year and Model:
I use white lithium grease on the door hinges,locks,hood latch etc.
I use 3in1 oil on the antenna mast. I will put a rag at the base while the antenna is up , oil it lightly and the lower it ,the rag will catch what drips off while closing
srnkanator
- Year and Model:
Heavy lubircant will build on antenna and mix with dust and dirt long term. Best to just keep it clean . . .
2010 XC60 T6 AWD
2005 S60 2.5 T
2010 XC60 T6 AWD
2005 S60 2.5 T
- Tsquared
- Year and Model: 11 C30
- Has thanked: 1 time
Tri-flow It is a teflon based lubricant. Works well on the antennae mast. I never open the sunroof, so I haven't lubricated it.
'11 C30 T5
'96 854 - died an early death with 184K miles. Killed by the front end of an LTD on a suicide mission (T-boned and both cars totaled).
Thanks for the replies everyone. I looked for the white lithium grease at one automotive store and they only had it in a tube looks like it goes into some sort of gun, sort of like a caulking gun.
I'm going to look at another store and try to find a spray can of it.
Thanks again!
Thanks again!
Klausc
- Year and Model: 1995 855 Turbo
- Has thanked: 5 times
- Been thanked: 15 times
I tried white grease on my sunroof hinges and wound up wiping it all off and using "3in1" oil. The white lithium grease was too solid in the dead of winter. Don't forget the forward hinges.
Do not use WD40 as a lubricant. It is an oil based cleaner and will eventually dry up.
Klaus
Klaus
Klaus
- 436 Views
Last post by viper69
- 20 Replies
- 3826 Views
Last post by cvtech
- 28 Replies
- 10707 Views
Last post by plumsmooth
- 4871 Views
Last post by 93SCMax
- 617 Views
