I've searched here and elsewhere for accurate wheel alignment specs without success. Several references say they are contained in the owners manual, however, I cannot find them. Can anyone point me to an authoritative source for both front and rear?
New to me '04 V70 got a firm bump to the rear wheel resulting in slight bend to lower rear suspension arm. I've repaired that and reset alignment with a string to zero toe. Driving results are excellent and much improved. But I'd like to know exactly what the specs should be.
Also, I realize front camber is not designed from the factory to be adjustable except by means of the play inherent in the two strut mounting bolts. Probably has less than one degree of adjustability. Though it may not make much difference in tire wear or drivability, I'd like to know what the camber should be
P2 V70 series wheel alignment specs
- DavidE7
- Year and Model: 01-07 V70, S60, XC70
- Has thanked: 67 times
- Been thanked: 93 times
The procedure is in VIDA for the V70. This is for XC70:
https://www.volvoxc.com/wp-content/uplo ... gnment.pdf
David E
2001 Moondust V70 2.4 293,000 miles
2001 Nautic Blue V70 2.4 231,000 miles
2004 Nautic Blue XC70 2.5T 258,000 miles
new: 2004 Black Saphire V70R 193,000 miles
2007 Titanium S60 2.5T 277,000 miles
2007 Magic Blue S60 2.5T 233,000 miles
2007 Silver V70 2.4 203,000 miles
P2 Volvos for every person in my family
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
.jrschwit wrote: 24 Apr 2025, 12:46 I've searched here and elsewhere for accurate wheel alignment specs without success. Several references say they are contained in the owners manual, however, I cannot find them. Can anyone point me to an authoritative source for both front and rear?
Here are the front camber adjusters. Find a level spot and just stand a 3 foot level upright in the center of the rim and not touching the tires. Measure the upper and lower lips of the rim as long as they are true with no excessive curb rash. Best to be no more than 1/8" neg camber but 0 is best. Do not do positive camber. The same for front toe using a measuring tape no more than 1/8" toe in. These cars will drift slightly due to age of suspension if zero toe.
https://www.1aauto.com/2001-volvo-v70-s ... 001-569-64
https://www.fcpeuro.com/blog/at-home-al ... n-your-car
- 815 Views
Last post by darrylrobert
- 633 Views
- 1669 Views
Last post by V50M66
- 1340 Views
Last post by MadeInJapan
- 1569 Views
Last post by a3inverter
