Sporadic clunking, squeeling, and otherwise very nasty noises occuring.
ABS code for left rear.
Pulled it apart today. Found grease build up on the sensor from a bad wheel bearing. It seems fine on inspection not a lot of play. Still, grease is there. No grinding in the bearing.
The driveshaft has a lot of play. I am thinking this is the culprit. My spare is larger than what came out.
So, if i just remove those shafts...how does that affect the ABS?
2005 xc90 t6 nasty noises from rear drive [ bad rear wheel bearing, 2 hour job]
Vova585
- Has thanked: 228 times
- Been thanked: 238 times
Remind me please if reluctant wheel is a part of the axle vs it is the integrated part into the wheel bearing. If to imagine that picture search that I found is correct. Reluctant wheel should be a part of wheelbearing. Nevertheless, if to imagine that both sensor and cogwheel and wires are intact- you should be all good in terms of Abs light. However, what will happen with rear diff if the axels will not be there? How do you plan to plug the holes in the rear diff unless you plan to remove entire rear diff+haldex+driveshaft. Possibly doing all that and removing fuse to the haldex system would limit Christmas tree on a dash to just vdsc light or awd. I would vote for proper fix which will be new bearing and used axle(if your diagnosis on both is correct)
- 57gretsch
- Year and Model: 2005 XC90 T6
- Been thanked: 2 times
Well, turns out it was not a bad axle but a bad wheel bearing. On the rear bearings, the ABS sensor ring is integral with the rear of the bearing. This had failed and was separated from the bearing. Hence the nasty noises.
New wheel bearing and all is good.
No good deed ever goes unpunished.
1997 855 T5, 2000 V70XC, 1998 V70 AWD Manual, 2007 XC70
- Been thanked: 4063 times
What was the labour hours on that rear wheel bearing job?57gretsch wrote: 07 May 2025, 03:08 Well, turns out it was not a bad axle but a bad wheel bearing. On the rear bearings, the ABS sensor ring is integral with the rear of the bearing. This had failed and was separated from the bearing. Hence the nasty noises.
- 57gretsch
Did the work myself. It took about 1 1/2 hours. With a beer break.
- 2239 Views
Last post by Mn10
- 23 Replies
- 2057 Views
Last post by volvolugnut
- 8656 Views
Last post by Ou2mame
- 21 Replies
- 2826 Views
- 11 Replies
- 3154 Views
Last post by theWIFES_S70
