2008 S60 2.5T 245k
I've been in the process of trying to replace my spark plugs. In doing so, I've found that the threads in cylinder #1 have become stripped and I'm having a hard time getting a new spark plug seated. I've tried various ways to try and lock the plug in place, but it seems the spark plug just keeps getting loose, working its way back out under load, eventually leading to misfires and then actually losing compression out the top.
Anyone tried a helicoil insert or something similar? I've seen some youtube videos on it.
https://www.youtube.com/watch?v=M8s-xcM ... =17&t=169s
One concern I have is how to make sure that the piston is at the bottom so that the thread cutter doesn't impact the piston?
Any other ideas/suggestions?
Stripped spark plug hole
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
Use a plastic straw as a “depth gauge” to tell if the piston is near the bottom of the stroke. If you think the piston is near the top, pull out the straw and click the starter a smidge. Then insert the straw again and see if the piston rose or dropped. You may have to do this a few times in order to find something near the bottom of the stroke.
- Has thanked: 987 times
- Been thanked: 1075 times
I did not watch the video, but use lots of heavy grease on the cutting tools to hold the metal cuttings.
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
I was about to ask, how do you keep the shavings out of the cylinder??volvolugnut wrote: 02 May 2025, 07:53 I did not watch the video, but use lots of heavy grease on the cutting tools to hold the metal cuttings.
- Has thanked: 2857 times
- Been thanked: 1332 times
You could fashion a narrow vacuum tube to a shop vac and pull out shavings that drop onto the piston.
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 117 times
- Been thanked: 271 times
I’ve used Heli coils lots, I’d say that is your best option at this point besides changing the head. Heli coils work well and are inexpensive. I’d want the piston closer to the top so you don’t lose any shavings down the ports. Not Close enough that you hit the top of the piston though. Vacuum out the shavings when you’re done.
2003 XC 70 (sold)
Tape makes a great vacuum hose adapter coupler.matthew1 wrote: 02 May 2025, 14:35 You could fashion a narrow vacuum tube to a shop vac and pull out shavings that drop onto the piston.
hu5ker555
- Year and Model: 2008 S60, 2015 S60
- Has thanked: 46 times
- Been thanked: 18 times
When installing a new spark plug thread insert, how important is it to rotate the crank so that the piston is down?
From some cutaways of the engine head, it looks like the piston motion wouldn't ever get that close to the tapping tool (sav-a-thread).
And perhaps having the piston at the top might make cleanup/vacuuming of the cuttings easier?
- 3071 Views
Last post by Roger_850T
- 1234 Views
Last post by Ou2mame
- 33 Replies
- 6592 Views
Last post by loosenut
- 2102 Views
Last post by SuperHerman
- 2152 Views
Last post by lrock
