Blend door actuator S80 -99 2,9 Topic is solved
taxi
Year and Model: V70 2000
Post by taxi »
Hi!
I havent been here for a few years, guess i finally became expert on the old car (V70 -99).
But three days ago i bought a S80 -99 automatic with temperatur problems in the cabin. Right side works fine, but on driver side i can only get warm to really hot. Climate Control unit can not bring temp down all the way, some air is always going through heater core. I can hear the air flap/blend door struggling a bit and then stop.
I started by removing glove box, revealing three actuator motors, and i thought the one closest to me was the culprit. I removed it, and moved the shaft behind a couple of turns back and forth. Now i cant get the little motor to go back on, maybe it requires more force than im comfortable with?
Now i wonder if i removed the wrong motor, found some info on the interweb that driver side temp actuator is on left side of the core and harder to get to?
1: Does anybody know which motor/actuator im looking for? Location?
2: is there a way to reset the climate control afterwards? I will replace battery immediately after i get this done, will that trigger a reset?
Thank you in advance and greetings from Sweden!
taxi
Post by taxi »
Solution: looked at the correct motor (left side) and hooked up the arm that had fallen off and now it works.
