Diagnosing coolant leak on 2015.5 S60
tflesui
Year and Model: 2015.5 S60 T6 Platin
Has thanked: 1 time
Post by tflesui »
Can anyone please help in diagnosing this coolant leak? As you can see I was forced to add dye as the leak is fairly slow and was hard to identify. There is a light coolant aroma inside which led me to believe the leak was from the heater core, but pulling back the passenger carpet, I could not find anything.
From the pictures it's pretty clear where the leak is but now I'm not sure what part I should be looking to fix. I'm assuming a hose but could it just be a clamp? Any help is appreciated, thanks in advance
2015.5 S60 T6 Platinum
2002 S60 T6
2000 S40
pjshackelford
Year and Model: 2015 S60
Post by pjshackelford »
I've got the same leak! Diagnosing currently...
Here goes a YouTube video that looks like the same issue... https://youtu.be/AxCvSsmUMSw?feature=shared
FCP Euro Part, Volvo HVAC Heater Hose - Genuine Volvo 8641078, https://www.fcpeuro.com/products/volvo- ... o-31338581
I'll do a bit more investigating and report back my findings
ZacharyShields
Year and Model: 2018 XC60
Post by ZacharyShields »
Watch the video on Youtube, it's quite informative: Squid Game Online
Thanks!
Soloris
Year and Model: 2015.5 XC60 T6
Post by Soloris »
That fitting is terrible. Had to replace it twice now.
Good trick for getting that quick connect off, angled needle nose can help pinch both sides since you tend to not be able to grab access both sides. Or zip ties to help compress.
Full hose assembly is 8641078
https://www.fcpeuro.com/products/volvo- ... 78#fitment
Also found just pulling the battery and battery tray out make access to the rear connection easier.
pjshackelford
Thank you for the help! I was able to drain the coolant, remove the faulty part, and fit the new part without major issues. I used a vacuum filler from Harbor Freight (per the FCP Euro and other forum guidance).
Vacuum Coolant Fill Tool Options
https://www.fcpeuro.com/products/pneuma ... 20#fitment
https://www.harborfreight.com/cooling-s ... 64985.html
Thus far I am not measuring any leaks and the level has remained steady.
