Hi all
Have a seal leak at the top of the pinion - input shaft seal. Have new seals (no 'how to' included) and the rack out. Rack is solid, bellows in great shape. Just need advice/documentation/how to replace the seals. Don't need/want to replace unit.
Any advice would be appreciated
Rack and pinion Seal replacement
Vova585
- Has thanked: 228 times
- Been thanked: 238 times
Never done this exact job myself, so can't be considered credible reference. I would try to pre-drill 2 small holes on opposite sides of the old seal making sure the depth of the drill bit will not go much more than the depth of the new seal. Using 2 metal self taping screws i would screw them into those holes once again trying to not go below the depth of new seal(simply not sure how it is built there so would not want to ruin anything). Using pliers I would try to slowly pull side by side to remove old seal. After old seal is out I would clean everything with clean rug and brake cleaner. When all is dry. I would take a new seal to the hardware store and try to find a washer which can be used to drive the new seal in. It should be big enough to cover almost entire new seal diameter with central bore allowing for shaft to pass through. Apply some light coat of new power steering fluid to the new seal and put it in with some hand pressure to start. Then put a washer and through the driver-tube(i would probably use pvc pipe 1.5 inch based on photo I would slowly try to tap it in making sure it is fitted evenly on all sides to the prior depth.
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
Thanks for documenting that , Chuck.
OP, be sure to put 50p into the slot on your computer.
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
Agree with the above sentiment... it's a marvel how much expense you can save by reading, learning and using all the info here. Really appreciative!
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
Try lightly heating the housing with a propane torch after putting the seal in the coldest freezer you can find over-night.
Marni
- Year and Model: 1998 S70 T5
- Been thanked: 3 times
Good Sunday all
It's gone from very rusty nuts (had to cut one off and will need to rethread bolt), bolts and all things as a result of Canadian conditions (winter, sand, salt) - (some of the videos I've watched on cars of this vintage are quite clean in the South
Definitely some envy
Anyway, after much effort including tapping, bevoling and lubricating, finally a measurement revealed the new seal was significantly - like 2mm - too large
. Double checked the order and the kit was correct accordingly to the vehicle. If a mid production change is the result (??) why not include both??
This is what we need-
Steering Gear Seal (19,05x34,6x9,2) Co12012530 Corteco 34002505
If course it's the weekend so another day delay
I'll post again when further along.
Btw - 98 Volvo S70 T5 2.3l
Owned since 2002
334000km
Owned since 2002
334000km
There were two makes of racks used on P80s, TRW and SMI. I wonder if you got that right one?
- 1204 Views
- 525 Views
Last post by j-dawg
- 1465 Views
- 1378 Views
Last post by alschnertz
- 1284 Views
Last post by oragex
