Rotor Pin
cham
Year and Model: 2001 V70
Has thanked: 23 times
Been thanked: 9 times
Post by cham »
I’m working on changing my struts and I found this on the rotor. Is this pin meant to be here when the wheel is mounted to the rotor? I can imagine it would affect the balancing of the wheel/tire. Should I remove it?
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
I believe that when the added weight is that close to the center of the rotating mass that the overall effect on the wheel balance is negligible.
Add that same amount of weight out at the edge of the rim, like where a wheel balancing weight would be, and the effect will be much more pronounced.
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
What car is that? It looks like P80 rotor pin?
jonesg
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
they're used on the assmebly line to prevent wheels from falling off before they are bolted on.
Has thanked: 1609 times
Been thanked: 4065 times
On some wheels the pin indexes the wheel so it goes on in the dynamically balanced location
Has thanked: 2199 times
Been thanked: 1851 times
I have never seen this on a P2, but guess it is possible. P80 cars had a point on the back of the rims with a hole in it to help align the wheel lugnut bolts at night should you get a flat. There was only one point on the back of the rims. However, later rims do not have this so it is pointless. I suspect you have a late P80.
dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 187 times
Post by dikidera »
scot850 wrote: 11 May 2025, 02:49 I have never seen this on a P2, but guess it is possible. P80 cars had a point on the back of the rims with a hole in it to help align the wheel lugnut bolts at night should you get a flat. There was only one point on the back of the rims. However, later rims do not have this so it is pointless. I suspect you have a late P80.
There are. There was on my P2, but when I installed my spacers I had to remove them.
cham
Post by cham »
My P2 has such a low Chassis code it shares many parts with the P80 platform. It’s an ‘01 but an early one at that. I had to order P80 strut bearings for this job.
One other thing guys, jacking/support points on this vehicle seems like a nightmare. Yesterday I supported the car with a jack stand on this subframe bolt. I had seen some people do this I believe. I’ve read people talk about warping subframe mounts etc and this was the recommended spot?
jonesg
Post by jonesg »
I usually move the stand a few inches rearward but it wouldn't bother me either place.
