Hi all does anyone have a wiring diagram for a 2003 volvo v70r abs module
I've recently bought a volvo v70r with fault codes, the wiring for the abs module has been chopped and joined again so im trying to diagnose someones mistakes, the best I could find is a diagram for a xc70 and the wire colours are in the wrong placed for 3 wires, they are wires relating to my fault codes so just wanted conformation that I've found my issue, any help would be grate thanks all.
- Been thanked: 4063 times
You will need diagram for you model and UK market as thst stuff is country specific
Ahh right. I might find that quite hard to find then, as it's a Japanese import.
thanks for all the information and help I'm gonna try contact a dealer to see if they could supply one for the exact car if I'm lucky.
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
3 wires can't be too difficult to sort out.Volvoror wrote: 12 May 2025, 12:45 I've recently bought a volvo v70r with fault codes, the wiring for the abs module has been chopped and joined again so im trying to diagnose someones mistakes, the best I could find is a diagram for a xc70 and the wire colours are in the wrong placed for 3 wires, they are wires relating to my fault codes so just wanted conformation that I've found my issue, any help would be grate thanks all.
find the constant 12v feed with a meter.
Then ground,
the 3rd wire should be the 5v signal....don't feed 12v battery power into that wire,
use a computer safe probe, mine only allows 500milli v.
- 927 Views
Last post by rice240
- 2593 Views
Last post by legalstuff
- 1862 Views
- 10240 Views
Last post by JDS60R
- 4145 Views
