XC70 throw ECM-671C after replacing camshaft position sensor
amolero
- Year and Model: 2005 XC70
- Has thanked: 3 times
- Been thanked: 2 times
My 2005 XC70 gave originally a P0342 code. I replaced the faulty camshaft position sensor and soon after it gives a 617C code (camshaft position, exhaust high), and also replaced the connector that have some small wire exposure. The car start at once, idle smoothly and run very well, no hesitation at all. If I erase the code and run the car, the check engine light will not come out while running. However, If I turn off the car and turned back on, the code immediately returns. I am not sure whether these cars require some sort of camshaft position sensor relearn. I have run the car around 100 miles with the hope of seeing some sort of self adjustment, but this has not happened. Any suggestion would be greatly appreciated.
Vova585
- Has thanked: 228 times
- Been thanked: 238 times
1. Where is this new sensor came from? If labeled "new" from ebay or Amazon even if Iin the box saying "volvo" i would question it's accuracy. If the old sensor is available try to compare dimensions. Even brand new oem from dealer might be bad from the box.
2. I would inspect the camshaft sensor instalation. Any chance previous sensor particles are left there and clearance between sensor and camshaft is altered?
3. If all checks ok, I would probably try to go to local salvage yard and remove 1-2 oem sensors for a "good luck" and try them on.
4. If that fails I would recheck timing marks. Check pindrag on the connector with small needles, check 5v reference(if I remember correctly it is 3 wire design). If that checks good i might try to look down the harness if anything shorting to engine ground especially at bends.
If that checks I would honestly say "it is time to drink beer" and bring it to dealer.
Of course there is opportunity to buy U-scope, PIco, spend hours on Dice looking at cam-crank signals, but for me it would be not worth the headache
amolero
I forgot to mentioning that I have previously a problem with the exhaust VVT solenoid. I replaced with a Febi Bilstein from FCP, but the problem persisted. Then I replaced with an original Volvo, and this problem was solved but immediately I got the code for a camshaft position sensor low signal on same bank1. This is why I proceed to replace it.
amolero
1. Where is this new sensor came from?Vova585 wrote: 14 May 2025, 08:24 1. Where is this new sensor came from? If labeled "new" from ebay or Amazon even if Iin the box saying "volvo" i would question it's accuracy. If the old sensor is available try to compare dimensions. Even brand new oem from dealer might be bad from the box.
I got the sensor from FCP. It is the Pro Parts Sweden
I also replaced the sensor housing with an original Volvo part. The camshaft was clean
I will swap the intake-exhaust sensors to see if this make a change.
I replaced both connectors and the proximal section of the cables. Your are right, these contain three cables (red, black and blueish). I notice a little exposition of the wire close to the connector, so I decided to replace them.
5. If that checks I would honestly say "it is time to drink beer" and bring it to dealer.
The beer is a good idea. I think the only other thing is that the timing is off. I replaced the timing belt, VVT selenoid, water pump and tensioners 6 months ago as my mechanics (which is not the dealer) told me that this repair would likely match the price of this old car. Now I feel I will have to come back
Vova585
Average new car is 55k or so. Yes, we all spend more on our old volvos than they are worth on marketplace. PPS would be my primary suspect at this point and I would much rather replace it with used oem. If you had no codes after replacing the timming belt and related items doubt the issue is there, but since you did all the work yourself and the code was there after the work, I would retest it all.
I like this instruction-visual. Let's hope it is PPS made in China "chineesium" problem and nothing more sophisticated
amolero
Thank you, Vova585.Vova585 wrote: 14 May 2025, 08:55 Average new car is 55k or so. Yes, we all spend more on our old volvos than they are worth on marketplace. PPS would be my primary suspect at this point and I would much rather replace it with used oem. If you had no codes after replacing the timming belt and related items doubt the issue is there, but since you did all the work yourself and the code was there after the work, I would retest it all. I like this instruction-visual. Let's hope it is PPS made in China "chineesium" problem and nothing more sophisticated
What is the PPS?
Keep in mind, my XC70 is a 2005 model.
- 1425 Views
Last post by volvolugnut
- 5216 Views
- 2528 Views
Last post by Labone
- 6843 Views
Last post by prwood
- 3822 Views
Last post by PixelDust
