Bypassing heater core 2004 S60
volvothaifactory
Year and Model: 2004 S60
Has thanked: 1 time
Post by volvothaifactory »
Hi all, in tropical area where I live, is there any potential problem if we delete the heater core permanently? would cooling capacity decrease for the engine & tranny?
Thank you in advance
dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 187 times
Post by dikidera »
I would imagine it would be negligible, since when you do not use the fan to blow on the heater core, it already saturates with heat and I doubt the small surface area with just radiation alone could affect temps in any positive matter.
What would be better for temps is installing a second fan behind the front bumper that could kick in earlier than the main engine fan. These cars have very ineffective cooling from the water pump at idle. I even thought about installing a second, electric pump to circulate the water at idle more effectively. But it was only a passing thought.
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
Go ahead. And add extra transmission cooler. May bypass heater exchanger in radiator altogether.
volvothaifactory
Has thanked: 1 time
dikidera wrote: 15 May 2025, 03:03 I would imagine it would be negligible, since when you do not use the fan to blow on the heater core, it already saturates with heat and I doubt the small surface area with just radiation alone could affect temps in any positive matter.
I agree with the ineffective cooling on these cars. By extra fan you mean a visco fan? I already imagine the struggle putting it in, in already cramped engine bay :cry:
volvothaifactory
Has thanked: 1 time
vtl wrote: 15 May 2025, 05:00 Go ahead. And add extra transmission cooler. May bypass heater exchanger in radiator altogether.
do you know some good OEM ones?
vtl
Post by vtl »
volvothaifactory wrote: 15 May 2025, 14:35 do you know some good OEM ones?
People fit XC90 ATF coolers in with minimal efforts. I have just a generic Hayden ATF cooler in line with heat exchanger and no thermostat, it works well.
volvothaifactory
Has thanked: 1 time
vtl wrote: 15 May 2025, 15:10
I see, just consult with my local volvo specialist, these things worn out the seals faster, and could be troublesome for the tranny in the long run he said :cry:
vtl
Post by vtl »
volvothaifactory wrote: 16 May 2025, 01:54 I see, just consult with my local volvo specialist, these things worn out the seals faster, and could be troublesome for the tranny in the long run he said :cry:
What? Find another one.
dikidera
Post by dikidera »
Not even remotely true my guy. But you will need just a bit more atf, to compensate for the added volume of the cooler. I have not installed an AUX cooler yet, but I do have an external filter with strong neodymium magnets attached to it(emulating Magnefine but poor mans solution)
darylrobert
Year and Model: V70 240 740t xc70
Has thanked: 6 times
Been thanked: 44 times
Post by darylrobert »
I did the heater core bypass a few summers ago. I will be restoring it to original when i get the chance. I can see if i can take pictures of it tomorrow oh and my car is stick. The amount of coolant going to the heater core is very little.
As for the engine fan, even on hot days mine hardly activates, ive had to check it in VIDA to confirm its still working.
I modified my cluster a few years ago with this OBD2 temp/speed TFT display that reads of the cars computer. the temp while driving sits around 90c but stop for any length of time and it goes up . i have the alarm set at 106c and have not had it activate even on 35c days
xc70 cluster mod
xc70 cluster mod
switch for heater core mod
switch mod.jpg (50.75 KiB) Viewed 448 times
