After sitting for a few years doing work to it I have gotten to a point of being able to get it back in the road.
I bought a new battery and as soon as I connect it I get the four way flashers and a no summary scenario. I have checked all fuses. Ran the selector through all gears several times.
The interesting thing is, vehicle will not lock all doors, windows won’t work, gas and trunk latch releases do not work.
I’ve searched here and YouTube. I have not found a good solution or a start to investigate.
What are some places to start?
Thanks,
Stephan
No start after new battery 98 V70 glt Topic is solved
stephansvolvo
- Year and Model: V70 GLT 1998
- Has thanked: 21 times
- Been thanked: 3 times
Stephan
84 240GL my first(sold)
88 240GL(timing belt killed it)
98 S70 GLT
73 IH Scout ii
98 S70 GLT
73 IH Scout ii
Vova585
- Has thanked: 228 times
- Been thanked: 238 times
Can you please clarify the events.
Was the car starting via boost prior to instalation of new baterry?
If not, I would suspect that some ground or harness is not connected. You mentioned that it stayed a long time and you were working on it.
I would remove the baterry and try to perform "hard reset" via contacting positive and negative cables together (this car has no onstar or similar system, thus save to perform) for 5 min and try to reconnect the baterry. If after above it behaves the same as prior. I would put a battery maintainer on it and focus on starting system get yourself a good wiring diagram and see if you have all powers and grounds to the ignition lock and from there to the starter relay and starter...if you will fix one area, rest are likely related
stephansvolvo
Thank you for this feedback. Prior to starting the work, the vehicle started and ran. I will go back through and ensure I have everything reconnected properly. Quick Look I didn’t see anything out of the ordinary. Cables are clean. But….ill work back through it.Vova585 wrote: 17 May 2025, 20:23 Can you please clarify the events.
Stephan
98 S70 GLT
73 IH Scout ii
98 S70 GLT
73 IH Scout ii
Vova585
Another important factor that might help us: is it "crank no start" vs " no crank" situation. If your starter motor engages and turns the engine at a normal rate/speed, but your engine is not starting- i would suspect low compression vs no spark/fuel...
Please provide more data:
1. When the last time car was driven?
2. For how long it was sitting?
3. What repairs were done between last time it run and now?
4. Crank no start vs no crank situation currently?
5. Currently do you see any lights on dashboard?
6. Check engine light?
7. Any chance you have any obd2 scanner to read the codes(would likely need to erase ton of previous codes and try to start again to see if any would be back indicating persistent/current issue.
Good luck
Good luck
stephansvolvo
I added answers to each number.Vova585 wrote: 17 May 2025, 23:44 Another important factor that might help us: is it "crank no start" vs " no crank" situation. If your starter motor engages and turns the engine at a normal rate/speed, but your engine is not starting- i would suspect low compression vs no spark/fuel...
2.5 years
2.5 years
Head replacement, timing, etc
No crank
All lights come in when I engage the ignition to start
Secondary Air injection and misfire cyl 5 (burnt valve) were the only two codes prior to work. No codes showing now
Cleared two codes still no crank
Good luck
Thanks
Stephan
98 S70 GLT
73 IH Scout ii
98 S70 GLT
73 IH Scout ii
stephansvolvo
Video added
Stephan
98 S70 GLT
73 IH Scout ii
98 S70 GLT
73 IH Scout ii
stephansvolvo
Maybe I added a video
Stephan
98 S70 GLT
73 IH Scout ii
98 S70 GLT
73 IH Scout ii
- misha
- Has thanked: 155 times
- Been thanked: 432 times
It means that security/alarm system is triggered...armed and immobilised.stephansvolvo wrote: 17 May 2025, 19:26 ...I bought a new battery and as soon as I connect it I get the four way flashers and a no summary scenario.
Use remote fob to deactivate it or a trick with locking and unlocking the doors with a key if you don't have a fob.
Also check battery cables and grounds.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
What were the codes saved before you cleared them?
Cees Klumper
- Year and Model: 2002 S80 T6
- Has thanked: 46 times
- Been thanked: 33 times
X2 on the alarm / immobilizer. Without fob giving 'all clear' signal it will not crank, AFAIK.
- 2561 Views
Last post by BladeRider
- 2098 Views
- 3201 Views
Last post by DeathRex
- 6509 Views
Last post by MauroV70D508
- 2579 Views
Last post by anacortesian
