Spinning Outer Tie Rod Thread - 2007 XC70
cmayo1
Year and Model: 2007 XC70
Has thanked: 51 times
Been thanked: 9 times
Post by cmayo1 »
More generic advice that something specific to Volvos.
When trying to undo the nut on an outer tie rod end, the bolt (shaft? thread?) that it is seated on keeps spinning. I've seen advice saying to put a jack underneath it to keep pressure on it, but I'm not sure that would do anything because it's not connected to the external body of the outer tie rod, if that makes sense. This doesn't seem normal, seems like a cheap part was installed previously. Any advice would be appreciated.
Cheers
2007 Volvo XC70
free time ≠ money
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Bc when you put a jack below the outer end of the tie rod, you push the bolt part upwards in the tapered hole, preventing it from spinning.
Propane torch is very helpful in this case.
I use only Lemforder or TRW brand.
cmayo1
Post by cmayo1 »
Tried heat but didn't work. I'll give the jack a go. Thanks!
2007 Volvo XC70
free time ≠ money
Has thanked: 1609 times
Been thanked: 4064 times
You can often use a tire iron to pressure the tie rod end and an impact to spin off
cmayo1
Post by cmayo1 »
I've got a crowbar I can try. My 'garage' is two complexes over, so walking back forth for tools I need is annoying, but I'd rather be sheltered from the rain
2007 Volvo XC70
free time ≠ money
