Uro oil trap box for 97 850
snugani
- Year and Model: 1996 855 turbo
- Has thanked: 12 times
- Been thanked: 3 times
Hey everyone. I'm going to be doing the pcv on my brothers car soon. just wondering if you guys would trust the uro separator box over the Volvo OE part. The Volvo one is backordered but I can wait if its much better to get the Volvo part
- Has thanked: 2199 times
First think is DO NOT use Uro hoses!!
There are only 2 parts I would ever consider buying from URO and this may be the 3rd. The 2nd option is to clean out the original part with brake cleaner or gasoline.
It is hard to know how bad it is until it is removed if that will be successful.
It is not a hard job, but not one you want a do over on as it takes a far amount of time to do.
You could try putting a request for a used one in the sale/wants section so you could try pre-cleaning one before starting on the job.
Have you tried non-Volvo dealers parts places like FCP Euro? They list both the Volvo part and one from Viaco.
Rock Auto also include one from Gates as well as the Viaco version. This is a Canadian link so prices in CDN$:
https://www.rockauto.com/en/catalog/vol ... trap,11800
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
No.
Vova585
- Has thanked: 228 times
- Been thanked: 238 times
I agree with scot850. URO box will hopefully work for you, but never ever use hoses from them or from IPD(mine disintegrated after 1 year and I am still mad at them).
- foggydogg
Putting URO anything on a car is a recipe for disappointment. If this is not a time sensitive issue - which it does not seem to be - the job is a fair amount of work; it would be prudent in the long run to wait for the right stuff.snugani wrote: 05 Jun 2025, 07:55 Hey everyone. I'm going to be doing the pcv on my brothers car soon. just wondering if you guys would trust the uro separator box over the Volvo OE part. The Volvo one is backordered but I can wait if its much better to get the Volvo part
UROsupport
- Year and Model: 2007 S60R
Hi everyone, Oil Trap 9146756 is the 151mm tall version for naturally-aspirated B5254FS engine for 1993 850 GLT and 1994-1997 850.
Oil Trap 1271988 is the 167mm tall version (with plastic heat shield) for turbo engine B5234FT in 1994-1995 850 after engine number 330414. It also fits engines B5244T / B5234T5 / B5234T1 in 1996-1997 850, as well as other C70, S40, S60, S70, V40, V70, and XC90 models.
If anyone has any feedback or premature failure issues with URO Parts' hoses or any other items, please contact us with the details so our engineers can investigate and we can get you taken care of, thanks! https://apaindustries.com/contact
Vova585
UROsupport, you made a name for yourself with amount of "good comments" on this site. Yes, your prices are great, but quality leaves more to be desired. I doubt that anyone who had to redo volvo pcv system job due to premature component failure will be using anything but oem quality parts. If you want to change our opinion about you I would suggest dramatically improve quality and start advertising on this website. You can offer some special discounts to to the members and maybe after some time more people would be using your products and rave about how great you became..until that magical moment I would stick with oem rubber componentsUROsupport wrote: 07 Jul 2025, 12:06 Hi everyone, Oil Trap 9146756 is the 151mm tall version for naturally-aspirated B5254FS engine for 1993 850 GLT and 1994-1997 850.
UROsupport
^ Thank you Vova 585, we'll have Engineering check out the rubber formulation used for those PCV hoses.
1271653: Crankcase Breather Hose, Oil Separator to Engine
1271654: PCV Valve Hose, Valve Cover to Oil Trap
1271771: Crankcase Breather Hose, Oil Separator to Engine
8653339: Crankcase Breather Hose, Bottom of Oil Separator to Engine
8692217: Crankcase Breather Hose, Oil trap to cylinder head
9146488: Crankcase Breather Hose, Flame Trap Fitting To Flame Trap Pipe
9146489: Crankcase Breather Hose, Oil Separator From Flame Trap Pipe
9146757 (Discontinued): Crankcase Breather Hose, Inlet Hose From Valve Cover to Oil Trap
30677388: Crankcase Breather Hose, Inlet from Engine to Oil Trap
- foggydogg
This is hilarious.UROsupport wrote: 07 Jul 2025, 15:47 ... we'll have Engineering check out the rubber formulation used for those PCV hoses.
Once your reputation is sullied, it takes a huge lift to get it back.
Who is going to gamble parts bucks on a job with 5 hours of labor to tear down the intake manifold and the struggle to get all those hoses into the snorkel with no leaks?
- 830 Views
Last post by phils94850
- 24 Replies
- 5470 Views
Last post by Darkskies65
- 35 Replies
- 11528 Views
Last post by songzunhuang
- 1652 Views
Last post by tryingbe
- 1317 Views
