My v70 has always radiated heat from the engine bay. That's no secret. It doesn't overheat at all.
The issue is either the battery or starter.
In the summer months, I'll drive somewhere, park, shut the car off and do whatever.
I'll get back and go to start the car, and it won't start. It acts like a dead battery where you turn they key and it clicks.
The Battery is brand new and fully charged. This happened with my old battery too.
I'll pop the hood and let the engine bay cool down for 10 minutes or so, and then it'll start again like there wasn't any issues .
Has anyone else run into this?
Odd battery/starter issue...00 v70xcse Topic is solved
jmartin919
- Year and Model: S70 GLT SE 2000
- Has thanked: 97 times
- Been thanked: 42 times
Fuel pump relay?
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
Starter likely getting ready to go.
- Has thanked: 2199 times
Likely the starter, followed by the electrical portion of the ignition switch.
levalexi
- Year and Model: 2000 v70 xc se
- Has thanked: 9 times
- Been thanked: 6 times
I'll give it a shot and replace it when I can.
It works fine every other time. I daily drove it back when it happened the first time over a year ago. It just seems to be when it gets hot out.
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
I had an intermittent symptom like this on my 97 855 and the root cause turned out to be high resistance inside the positive battery cable at the terminal post -- the crimp was failing, leading to a large voltage drop. You can measure the voltage drop between the battery and the starter and see if it's higher than normal when you're trying to start the car (should be below ~0.2V). In my case replacing the cable fixed the issue.
levalexi
jreed wrote: 07 Jun 2025, 06:08 I had an intermittent symptom like this on my 97 855 and the root cause turned out to be high resistance inside the positive battery cable at the terminal post -- the crimp was failing, leading to a large voltage drop. You can measure the voltage drop between the battery and the starter and see if it's higher than normal when you're trying to start the car (should be below ~0.2V). In my case replacing the cable fixed the issue.
My buddy's looking at it tomorrow for me. I'll have him give that a look.
I was chasing a no start issue last year, but it was because of the terminal end on the solenoid, so this is a possiblity.
I'm just not understanding why it's only on hot days after the car has been driven.
Let us know how it goes. I still suspect the brushes are worn out on the starter.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
I also vote for bad/corroded battery cables.
Symptoms are magnifying with heat soak.
2awg(25mm2) wires should be used as a replacement.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 40 Replies
- 5815 Views
Last post by shiloh51933
- 899 Views
- 590 Views
Last post by 850TurboTurtle
- 1055 Views
Last post by jonesg
- 2189 Views
