No Start or Crank (I'm pretty much confused) Topic is solved
S70GUY
Year and Model: S70, 2000
Post by S70GUY »
I'll describe this as briefly as possible: I have a strange problem with my car and I don't know what it is, It's already giving me a headache and I don't know exactly what to do about it.
VID_20250607_223331088.mp4
(36.69 MiB) Downloaded 102 times
Problem I have
screen-20250607-223456.mp4
(1.37 MiB) Downloaded 71 times
Live Data using a OBDII Scanner
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Engine is cranking but cranking is weak.
Not enough power to start the engine.
I would say that battery is almost flat since odometer & trip readout is blank(------).
'99 & '00 needs a healthy battery voltage to start and run since they have DIS(distributorless) system.
11.9v is flat battery.
Try to jump start it or put a good battery.
When we rule that out...then you need to inspect battery cables for voltage drop.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
S70GUY
Post by S70GUY »
The blank odometer and trip is due to the abs module I have (it's bad) also I put the battery to charge all night, goin to check it rn
misha
Post by misha »
You should have total mileage displayed in upper row and 0.0 in lower row if it's because of bad abs module...since mileage is stored in the cluster not abs module.
You can power up the cluster on the bench and it will always display total mileage stored in the cluster.
Total mileage folows the cluster...not the car.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
yanga001
Has thanked: 62 times
Been thanked: 115 times
Post by yanga001 »
misha wrote: 08 Jun 2025, 02:32 Engine is cranking but cranking is weak.
I agree with what misha is saying here. The 99 and 00 need more power and will have a no crank no start issue.
A bad (low capacity battery) can cause this issue too. Had this happen when my battery dropped to 50% capacity over time. The car refused to crank/start but would have enough power to show the display.
2008 S60 2.5T Auto (Sold)
S70GUY
Post by S70GUY »
The problem is, the battery is new from store (it's been on the car for at least 4 or 5 months)
misha
Post by misha »
That doesn't matter....the battery shows voltage of 11.9v.That is flat battery.
Full battery must read 12.7-12.8v.
12.2v is 50% charge.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
If the electrical charging system is not right, the battery will lost charge (go flat) over time. Even as few months old battery will lose charge unless charged by the alternator system.
Has thanked: 2199 times
Been thanked: 1852 times
Have the battery professionally tested. It sounds like the battery has a bad cell in it. Once replaced/recharged, have the charging system checked for efficiency. Old battery leads with bad resistance or corroded/loose/broken grounds are also an issue to check.
If the battery continues to drain, check for a parasitic drain (something not switching off when you remove the key and lock the car).
S70GUY
Post by S70GUY »
Thanks for the advice, going to check rn
