Hi All - curious I have a tad over 100K Miles on my V70. I have to replace the alternator, so was thinking about replacing the PCV box while I was in there. Car had no codes or reason to change it, just was thinking maybe as part of preventative maintenance. I honestly don’t want to, this is the third alternator I have had to replace, so kinda just want to get it back together but labor wise, if it makes sense….
Doing a little research on YouTube, I see they can be problematic…. Although this is my second V70 and I have never had an issue.
Thank you in advance, Tim
PCV 2006 V70 2.5T
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 132 times
- Been thanked: 126 times
Do the glove test.
At a minimum, do the banjo bolt. My PCV when I serviced it was actually in good shape. All vacuum hoses in that area- that's a different story..
04s60 2.4
04xc70 2.5t
04xc70 2.5t
TimothyPaul
- Year and Model: 2006 V70
Thank you, I was thinking that too. Is the banjo bolt hard to get to ?
- br0dy519
With the alternator removed it’s a breeze. There is an extensive thread on the forum regarding the 2014 updates to this bolt. The old design has the potential to total your engine.
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- br0dy519
Hey- why does your alternator keep failing? What brand is stamped on the voltage regulator?
Anything other than OEM or quality rebuilders fail. I replaced 3 on my XC70 before I finally fired the rebuilder for using cheap parts.
04s60 2.4
04xc70 2.5t
04xc70 2.5t
TimothyPaul
I am a little baffled on the alternator. My original one failed in May of 2024. I had it replaced by a local mechanic and (for me) the cost was excessive. So last week I got the power system failure light. Put a volt meter on and was only getting 11.5V while running. The battery was also fairly new and had an about 12.5 volts so I just assumed it was the alternator. Called the mechanic and he said it was a one year warranty so even though it was 3 weeks past, wanted full price for a new one, and because he could not get the brand he used before, he could only get the Bosch, it was going to be $200 more. So I figured I would tackle it myself.
I got a replacement from O’Reilly. I put it in and still had the Power System failure light. Drove it over, and they said they tested, said battery good, but regulator bad. At the same time, I had them test the old one and it tested fine, which I found strange. The new one however is putting out 13.5 volts, so I know it is at least charging the battery.
So I had two ideas. Of course O’Reilly said no problem on replacing the alternator. I actually was not aware of the different regulators until reading more threads, so now I know. I was also thinking of taking the old regulator and trying it on the new alternator. Haven’t really decided yet. I found the most difficult part of replacing the alternator was getting the old one out between the engine and the radiator and getting the new one in. So I am kinda dreading that part.
I am in south west Florida and the temps are already “feels like” +100 degrees and the joy of self repairs fades fast….. lol. Plus. I have a 71 Olds I need to do a complete front end on.
