1999 ME7 flooded engine, does flooring gas pedal stop fuel being injected?
Has thanked: 1613 times
Been thanked: 4077 times
Per subject line
Does anyone have info if ME7 , 1999- engine management has a feature to shut off fuel injection during cranking to aid in starting a flooded engine?
How about Montronic 4.4 ?
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
I believe that procedure works on carburetors or throttle bodies that are cable operated. In those days, pushing the pedal to floor while NOT cranking the engine, opened the butterfly and allowed air in without any gas being squirted in. You just held the pedal open for a bit to let things air out.
I can't see how that would work with a ETM, since there is no mechanical way to just open the butterfly alone.
1999 V70 GLT
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1078 times
Post by volvolugnut »
It would be interesting to find a fuel shut off feature at full throttle while cranking. Most younger drivers would have no idea to try this. A hidden Easter Egg.
Has thanked: 2215 times
Been thanked: 1853 times
You've asked a question I would never have thought to ask, so naturally no help. I'm assuming you mean flooded by fuel and not water......!
I would have just pulled the plugs, pulled the fuel pump fuse or relay and spun the engine and left it over night to evaporate.
I'd also leave the plugs out to allow them the dry out. At home I would also plow them out with air.
You never stopped learning on here!
Sveedy
Post by Sveedy »
A throttle body can't even be flooded since it hasn't any fuel in it. So I'd think the easiest way would be to just pull the injector relay and turn the engine over a few times. That should clear any fumes out of the cylinders.
1999 V70 GLT
Vova585
Year and Model: 01v70xc,2016xc70...
Has thanked: 228 times
Been thanked: 238 times
Post by Vova585 »
I might be wrong, but I think abscate was interested in diagnostic testing value of "clear flood mode".(see compression test or attempting to clean extra fuel from engine). I know that most of Fords still support this feature(at least my 15 F150 has), but dont know about this generation of volvo Motronic 4.4
Correct from Rochester, City of Light and Bears
BMW has this feature and I think they run a lot of ME7 adaptations
