2004 V70R, 185,000 miles, M66
I have an issue. The dipstick has started to pop out occasionally, usually after a long drive in hot weather. I did the glove test and the glove didn’t inflate or get sucked in, it just fluttered. I had a good look at the dipstick and the O-rings are hard and flat, and I think that’s where I should start. Anyone have suggestions about getting a new dipstick vs new O-rings on the old dipstick? Should I stick with Genuine Volvo, or has anyone tried aftermarket parts? Thanks.
Dipstick pops out
imaV70Rdriver
- Year and Model: 2004 V70R
- Been thanked: 6 times
imaV70Rdriver
@dikidera,
Even though the glove test passed?
imaV70Rdriver
@ Vova585.
Thanks, I’ll get them from my local dealer this week.
Happy Father’s Day all you Dads out there!
- Krons
- Has thanked: 198 times
- Been thanked: 215 times
If it doesn’t suck in, you failed the glove test. I’d leave the dipstick out a bit (or cut a piece of the oil cap gasket out ) to allow any pressure to escape should the car need to be driven before the PCV system is redone. It could save your cam and crank seals.imaV70Rdriver wrote: 15 Jun 2025, 12:07 I did the glove test and the glove didn’t inflate or get sucked in, it just fluttered.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
It failed, you just didn't test it fully
Common parts to check/replace is that long expensive hose: https://www.rockauto.com/en/moreinfo.ph ... &jsn=11002
Banjo bolt (it has a valve inside, which gums up over time): https://www.fcpeuro.com/products/volvo- ... vo-8653884
PTC valve: https://www.fcpeuro.com/products/volvo- ... vo-8653644
Deformed PTC grommet: https://www.fcpeuro.com/products/volvo- ... vo-3507985
Or a hole in the intake hose: https://www.fcpeuro.com/products/volvo- ... o-30680446
In case you find PTC grommet bad, I'd suggest to replace the whole hose. It's extremely tight fit, you may mangle or even break the hose while attempting to replace that darn grommet. Ask me how I know.
If you checked/replaced PCV and the engine still shows signs of excessive crankcase pressure, you have too much blow-by gases then. Worn out piston rings and bore taper are the causes of blow-by.
imaV70Rdriver
@vtl
It’s a manual (M66). Are you able to instruct me on how to do the glove test under boost?
vtl
Does it have a neutral switch? Maybe try it in the first gear, with clutch depressed?imaV70Rdriver wrote: 16 Jun 2025, 09:14 @vtl
imaV70Rdriver
I don’t know what you mean by “neutral switch”. The only neutral I know of is in between gears. I’ll try the glove test again later today in first gear with the clutch depressed.vtl wrote: 16 Jun 2025, 09:17Does it have a neutral switch? Maybe try it in the first gear, with clutch depressed?imaV70Rdriver wrote: 16 Jun 2025, 09:14 @vtl
Thanks for the parts info. I’ve watched a few videos too, it’s always good to get a visual of what I’m in for.
- 2853 Views
Last post by xHeart
- 685 Views
Last post by dyn blin
- 2362 Views
Last post by ZionXIX
- 899 Views
Last post by Bandit123
- 22 Replies
- 4644 Views
Last post by newbieofthenorth2+
