How to replace Hydraulic engine mounts? 1994 850 Turbo wagon
I have always turned my own volvo wrenches, but man I am stumped on this firewall side hydraulic mount. Does anyone know any pointers? I cant seem to even get the steel bracket loose around the mount. I have replaced all the others, but this one ruins the weekend... 1994 volvo turbo wagon....Thanks for any help Ryan
- Has thanked: 17 times
- Been thanked: 35 times
Car up on jack stands...jack under the engine with a piece of wood to support it....lower the back section (firewall side) of subframe...should be a piece of cake if you can get it this far. Use lots of PB Plaster in the major bolts.
ccgaudette
- Year and Model:
Interesting. I recently replaced most of the engine mounts, save the two hydraulic mounts. I have heard that the rear hydraulic hardly ever wears-out. Once you had it out did it look like it needed replacing? Did replacing it make a difference in road feel?
♂ 1993 U.S. Volvo 850 GLT sedan, 20-valve, N.A., 4-speed Auto. Trans., 180,000 miles
I made myself do all the mounts, My 850 has 160K on it and had a little vibration. I saved the back hydralic for last, and it made the biggest difference. It basically fell into two sections upon removal, I think the turbo and living in arizona cooked it well. No more Vibration and the engines angle is quite different, having lifted the motor up 1-2 inches with new mount.
- 2038 Views
Last post by charleskennedy23
- 1485 Views
- 2040 Views
Last post by jimmy57
- 8143 Views
Last post by theWIFES_S70
- 1354 Views
Last post by sleddriver
