Should I continue with the Volvo 850? Topic is solved
Vulva15853
Year and Model: 1997 850 GLT
Post by Vulva15853 »
I picked her up for $500. She has 120,000 miles on the odometer, interior is pretty minty, all power options work (except for A/C) No signs of rust anywhere on the exterior even underneath. The glove test failed, so I did the PCV cleaning/upgrade and found that the PO recently had done these (he had died, I wasn't able to confirm this until I dug into it). I'm still getting excessive pressure from the dipstick and oil filler. Should I keep digging and fix her or cut my losses and send her to the junk yard?
Vulva15853
I've also replaced all the vacuum lines and one-way valves.
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
Keep it. Particularly if it's rust free. If you toss it, you'll just end up looking back and thinking " What if I'd done this ...?"
If the car has been sitting awhile the rings might be a bit stuck. At least keep digging and do a compression test etc. 120,00 is pretty low for its age.
At a $500 starting point, you have a bit of room to play.
1999 V70 GLT
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
Junk yard? That seems extreme.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Vova585
Year and Model: 01v70xc,2016xc70...
Has thanked: 228 times
Been thanked: 238 times
Post by Vova585 »
In some instances the oil pan needs to be dropped to properly clear all passages. Engine overall is pretty simple without much electronics, one can possibly justify to throw a new set of piston rings as minimal investment.(minus time dedication)
wheelsup
Has thanked: 16 times
Been thanked: 22 times
Post by wheelsup »
If you want a cheap easy fix, just pull the oil dipstick out and attach radiator hose or similar to the tube and route it underneath the engine bay. This will alleviate the pressure in the crankcase and preserve the RMS.
DennisCA
Has thanked: 6 times
Been thanked: 67 times
Post by DennisCA »
An 850 is definitely worth it. Any late 90s car in good working condition and without rust issues, particularly a Volvo, is worth a lot.
Consider the development of cars since 2000 and the state we're in 2025. Having an old reliable car in the future is just getting harder and harder.
These cars will become worth more simply because of this as the new reality and cost of cars starts sinking in with people . I'm already seeing the beginning rumblings and things will grow worse IMO. Imagine being say the 3rd or 4th owner of a 15 year old wet belt engine car and no parts have existed for it for 5 years, yeah that's the future.
5underpressure
Year and Model: 1998 v70
Has thanked: 11 times
Been thanked: 13 times
Post by 5underpressure »
For most any vehicle not rusty, the junkyard is a terrible place for it to go.
Vulva15853
wheelsup wrote: 23 Jun 2025, 22:25 If you want a cheap easy fix, just pull the oil dipstick out and attach radiator hose or similar to the tube and route it underneath the engine bay. This will alleviate the pressure in the crankcase and preserve the RMS.
How long can you run these with this "fix"?
Has thanked: 1610 times
Been thanked: 4065 times
5underpressure wrote: 24 Jun 2025, 12:01 For most any vehicle not rusty, the junkyard is a terrible place for it to go.
When they do go they should look like this….
