Automatic transmission fluid brand recommendations
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
.Rcooper wrote: 25 Jun 2025, 05:19 1998 S70.Is castrol automatic transmission fluid good?or is there another brand that would work better.
Use to have a 98 S70 T5 back in 2012. Currently a 00 S70 SE NA. Both are not that sensitive to transmission fluid though I found the Swepco 714 20W to work best for most of my cars transmissions. Worked especially well on the 98 S70 T5 with a complete flush. Mine was coffee dark with a hew of sliver at 230K miles when purchased. The 4 speed in the 98 is a strong transmission compared to the 99 and 00 5 speeds. I like the shift better. Currently have 5 auto Volvos to compare with and 1 M66.
This should work well.
Now $6.98
Castrol Transmax Import Multi-Vehicle Automatic Transmission Fluid, 1 Quart
https://www.walmart.com/ip/Castrol-Tran ... irect=true
Was under $6 when I started using it maybe 20 years ago. I only stock this as an additive due to cost although I recently found a Close Out so stocked up. Will use one or four quarts after a drain and fill or complete flush.
Swepco 714 Hydraulic Transmission Fluid Type TO-4/C-4 20wt. Gal.
https://www.amazon.com/Hydraulic-Transm ... hdGY&psc=1
aeg
- Year and Model: 97 850GLT
- Has thanked: 2 times
- Been thanked: 46 times
The 4-speed automatics originally took Dex/Merc, but Volvo has said JWS3309 is also OK and may give smoother lockup engagement (Tech Net Note 40-04 and Service Bulletin 43-0029). One option for JWS3309 is Toyota T-IV, part number 00279-000T4-01 for 1 quart or 00279-000T4-6S for 6 quarts, about $6 a quart from the Toyota dealer. Many people are running this in their Volvos.
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
In my '97 855 GLT (~260k miles), I have had good results with Castrol transmax high mileage ATF, with wife reporting smoother shifting compared to Castrol Dex Merc, the previous fluid I used.
Valvoline Dex6 Synthetic recommended by Volvo tech jimmy57 here. Great price in the jungle if you wait a month or two.
- 1002 Views
- 1154 Views
Last post by Krons
- 15 Replies
- 7623 Views
Last post by jtbgonesailing1
- 866 Views
Last post by difflock54
- 3334 Views
Last post by pmondrian
