XC70 P2 handbrake leather replacement
mscarrock
Year and Model: xc70
Been thanked: 2 times
Post by mscarrock »
I have XC70 2004 AWD 2.5T. I couldn't find any instructions of how to replace the old leather of the handbrake leather so I took some photos. There are two frames that hold the leather in place. You need to separate those. Mine were clued / plastic welded so I had to use a small flat screw driver to break the connections.
I figured there were 5 to 6 connections I had to break loose. Not too difficult, I used the small flat screw driver and gently pryed / hit gently with a hammer. The last corner is the most difficult, see the pic. Otherwise just removed the staples and the old leather came off. The new wasn't exactly cut but I did my best to re-attach it with double-sided tape. I used hot glue gun to place the new learher in and frame in place. Looks pretty fine and I'm okay with it.
The last corner is the most difficult one to brake but I managed to to pry it loose like in the pic. Take your time and be patient! It'll come loose. The pic is the 3rd last.
Krons
Year and Model: 08S60 05XC90 02S60
Has thanked: 198 times
Been thanked: 215 times
Post by Krons »
Did this on a tattered S60, fiddley install but well worth it! Good result on your car.
08 C702.5T (sold)
The non-Swedes:
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 117 times
Been thanked: 271 times
Post by Blacklab467 »
As a bonus, you can source a real leather hand brake handle from an S60 and ditch the plastic one that comes on a XC70. It will then match the leather that is on the shift knob.
2003 XC 70 (sold)
dono
Year and Model: 04 V70&XC70 2.5T AWD
Has thanked: 43 times
Been thanked: 6 times
Post by dono »
Curious where you sourced the replacement part...
2004 V70 AWD Wagon 2.5L L5 DOHC 20V TURBO 268k mi :D
2004 XC70 AWD Wagon 2.5L L5 DOHC 20V TURBO 155k mi :D
1999 Mercedes e320 4Matic 238k mi :D
2008 Toyota Avalon XL 165k mi (meh)
Krons
Post by Krons »
dono wrote: 12 Jul 2025, 14:49 Curious where you sourced the replacement part...
My new aftermarket pleather one from years ago I got on eBay. Color match was far from perfect but a huge improvement from the tattered old one.
08 C702.5T (sold)
The non-Swedes:
