Hello!
I am new to this group and need help. I recently had ignition coils and spark plugs replaced after my 2011 XC70 died and would not start. They said the wires were "fried" and you could definitely smell burning plastic. A few days later, check engine light came on. The code was P0091 for fuel rail pressure sensor. Car was running fine. the light went off the next day. I called the dealer and they said not to worry about it if the car was running and starting OK. They said their would be warning signs, "hard starts,etc", of the sensor was starting to fail.
Last week the check engine light came back on. The code was again for fuel rail pressure sensor. The car was starting and running fine, but I decided to replace the sensor just in case, just to be safe.
The dealer replaced the sensor. About an hour after picking the car up, it died and would not start. It would crank but not turn over. The car had been running fine prior to replacing the fuel rail sensor.
The dealer towed the car and after looking at it for a couple days is telling me the fuel pump needs to be replaced.
They said it was probably just a coincidence the fuel pump went out after replacing the sensor.
I don't believe in coincidence and am wondering if it was something they could have done? They said it was also possible the fuel pump was bad and the sensor was fine? In that case, they would not charge me for replacing the sensor.
I asked if it was possible it could be a wiring problem, fuel line, etc. They said they wont know for sure until they take out the fuel tank. They are quoting me $2600 to replace the fuel pump!
I find it very odd that with the exception of the check engine light coming on and (then going off), the car was running fine, until they worked on it and replaced the fuel rail sensor.
Please help! Your expertise and advice would be greatly appreciated!
Thanks!!
Fuel rail sensor replaced now won't start
Vova585
- Has thanked: 228 times
- Been thanked: 238 times
Sometimes it is just bad luck. I doubt that dealer would be knowingly telling you lies and not try to sell you fuel pump and sensor at the same time as ignition coils or fuel sensor. You now can opt to do it with dealer for 2600. Maybe tow it to indy who would be willing to do it for around 1800-2200. Or be willing to do some damage and cut a piece of body metal to gain access to the fuel pump and replace it without dropping the tank(dealer would never agree to such since they have protocols). Look some videos on YouTube about this option and decide if it is worth your time. For 2011 I woukd say to hell with it and gently cut openening, replace pump and put some sheet metal over with good amount of auto silicone around. Probably $400 if done by yourself or around 800 to pay someone willing to do it(they would require you to sign waver stripping them of all responsibilities)
MVM17
- Year and Model: 2011 XC70 T6
Thanks for your reply! I know the dealer is reputable and would not knowingly lie to me. My concern was that since the car was running fine,(except occasional check engine light), before replacing the sensor, could it have been something they did,(loose wire, fuel hose,etc), to cause the car to die or was it just a coincidence it died after they replaced the sensor?
Or could the pump have been failing and caused the sensor code?
