Alternator not charging battery 1985 240dl
OntheDL
Year and Model: 1985 240dl
Has thanked: 3 times
Post by OntheDL »
I recently changed my water pump and alternator on my 1985 240. Before I even drove a half mile the dash lights all lit up. Getting charge from the battery but not putting out current to charge the battery. The B+ is not increasing to 14 the D+ is not even getting a 1/2 volt whether the key is turned on or running idle. Any ideas of what could be causing the problem?
Vova585
Year and Model: 01v70xc,2016xc70...
Has thanked: 228 times
Been thanked: 238 times
Post by Vova585 »
Question 1: do you still have old alternator?
2: why you decided to replace alternator if old was good? (Just my assumption)
3. Check if all connections are tight.
4. Check voltage drop test for positive and negative side.
Most likely you new alternator is defective(was good before, installed new and now problem..)
In case you need guidance on troubleshooting this issue go to "scanner danner " youtube channel he has several videos on this topic.
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Likely you have a bad connection at the alternator or left a wire loose when installing.
Is the belt installed correctly and still tight? Is the belt wet?
Is the alternator correct for the Volvo?
OntheDL
Post by OntheDL »
Thank you for the suggestions. I fiddled around with the wires inspecting them. I think I am pretty sure what the problem is, the wires for the exciter and oil pressure sensor. have attached a photo of the wires they are at the position of under the crack case. I Any suggestions where to find replacement or splicing?
Cut out and replace bad wire with crimp connections covered with shrink tubing. Even better, use soldered connections covered with shrink tubing.
Cover the finished wires with new split wire harness cover.
