Parts available July 20 2025
Cylinder head
Cat and exhaust
ETM
Alternator
Starter
Ac compressor
AC low pressure line
AC high pressure line
AC compressor suction line
Ps pump
Fuel pump
Brake booster
Brake pedal position sensor
AB’s module
Tailgate
Doors
Fenders
Hood
Turn signal stalk -gold plated for the Texas NM market
Gold pressed latinum for AZ
Possible short block
Possible 5 speed transmission
2000 V70 FWD > BerylVolvo Admiral "Grace" Hopper USN (ret) < 417-26 Antlia YV1LW61J9Y2706562
Forum rules
Please create one topic per Volvo you own. Then simply post to that topic when you maintain or repair your Volvo. You'll have a nice record of what you did, when, and how much it cost. Only you can post in your topic.
- Been thanked: 4063 times
- FF410F1C-8E6F-4271-8280-D3621267AB0B_4_5005_c.jpeg (31.88 KiB) Viewed 3290 times
- 8251F9CB-D565-4625-A4D7-993654C705AB_1_105_c.jpeg (112.9 KiB) Viewed 3290 times
- 1199BA62-5910-4A2B-B411-26404503A06D_4_5005_c.jpeg (27.43 KiB) Viewed 3290 times
- 6089AE0C-CBC5-4A61-89A1-4254A556CAB8_1_105_c.jpeg (98.07 KiB) Viewed 3290 times
- B62518A6-B159-4306-B2F2-F2EC15C2F6DE_1_105_c.jpeg (91.49 KiB) Viewed 3290 times
- F51480AA-4041-4273-8359-E55A19974330_1_105_c.jpeg (112.97 KiB) Viewed 3290 times
- Has thanked: 2196 times
- Been thanked: 1850 times
5-speed manual or auto? If auto, on a 1999? Thought it was only fitted to 2000 model base and R models.
It’s a 1999+1 , sorry
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
I'm in Arizona, so I need the copper plated version or it won't work.
According to one of Roberts videos, it's probably the collar piece behind the steering wheel. I'll have to pull mine first in order to make sure we have a match.
1999 V70 GLT
1999 V70 GLT
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
Let me get this straight….you’re letting go of a Nautic Blue P80 wagon??
5underpressure
- Year and Model: 1998 v70
- Has thanked: 11 times
- Been thanked: 13 times
Interested in the alternator, picked one up from a guy on swedespeed.
I dropped my original off they were unable to source a part to rebuild it.
Tailgate latch? Compatible with a 98 v70?
ABS unit?
ABS unit?
- FireFox31
- Has thanked: 159 times
- Been thanked: 303 times
I'm interested in the steering rack, rear wheel hubs, carpets (if beige), likely a bunch more. I could use front driver's seat foam if it's compatible with 1998 airbags (I forget off hand). Heck, I'd take all the seats if they're beige, in good condition, and compatible with a 2000.
FireFox31
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
Should have had it delivered to your place. It would have arrived in mere minutes and you could have had your choice of bits.FireFox31 wrote: 17 Jul 2025, 00:24 I'm interested in the steering rack, rear wheel hubs, carpets (if beige), likely a bunch more. I could use front driver's seat foam if it's compatible with 1998 airbags (I forget off hand). Heck, I'd take all the seats if they're beige, in good condition, and compatible with a 2000.
- FireFox31
In the future, that will be an option. Right now, less so. I'll be near Deleware for a while in case I need to remove and pick up the bits. Keep me posted.
FireFox31
Well, this might end up in my kids program. Foggy tells me it’s the straightest, most perfect car he’s seen out of CapAuto in a while.
Oh well, the road to Hades….
Firefox, I still have all those parts lying Long Island
