I am looking for procedures to replace the transmission mount, rear motor mount, and front lower torque strut mount. Did not find any repair videos.
Also has anyone used the repairsurge online repair manuals.
2013 Xc60 3.2
Thanks
2013 xc 60 3.2 engine mounts replacement
xyourobob
- Year and Model: 2004 XC90, 2011 XC60
- Been thanked: 4 times
I just replaced the lower transfer case/engine Mount and the upper mount (long one on top of engine) the top one was dead easy, just unbolt, remove and replace. On the lower one, you have to crawl under and use a 15mm socket on the bolts going through the brackets, the larger bolts on the other side of the bracket are welded on to the bracket, believe me that's a good tip. Then remove the 2 15mm bolts that attach it to the subframe. I put the bracket on the new motor mount then slid it into position. I haven't replaced the other 3 mounts yet.
- Krons
- Has thanked: 198 times
- Been thanked: 215 times
This one?
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- 969 Views
Last post by 2forty
- 1447 Views
- 1288 Views
Last post by SuperHerman
- 740 Views
Last post by pixie7684
- 1097 Views
Last post by Meetgizmo
