Hello! I just bought 2.0 S40. I have an issue with the fuel gauge. It reads below empty with the engine off and then empty with the engine on. Even with full tank.
From what i know, the sending unit is ground operated and if the tank is empty resistance is 0 and if full resistance is in upper limit (usually 0-90 ohms).
So disconnecting the sender unit would create infinite resistance and make the gauge read full. I removed the conector from the pump/sending unit but the reading remains empty.
Fuel Gauge reads Empty 2003 S40 2.0
- 812 Views
Last post by 93Regina
- 706 Views
Last post by xlr8r3
- 13 Replies
- 739 Views
Last post by NotAnElectronicsGuy
- 1378 Views
Last post by CanadianRob
- 361 Views
Last post by vtl
