Defroster Issue
I have a 2014 XC90 with no air blowing out the defroster when the max defrost button is depressed and lit up. I have performed a calibration and reviewed scan data. No codes are stored in the CCM and when requested the scan data shows 0 for the defroster position. If you select upper on the CCM I get air out the defroster the data reads correctly. I replaced the servo motor for defrost door but I still get the same result. I did perform LIN test and calibration. Any clues as to why the max defrost is not working correctly?
- 418 Views
Last post by mercurysys
- 1467 Views
Last post by KBlue_V70
- 3146 Views
Last post by 93Regina
- 11 Replies
- 2301 Views
Last post by BEJinFbk
- 11 Replies
- 3311 Views
