Hello,
My friend contacted me with a problem that she’s having with the sunroof on her 940 wagon. She told me that the fuse was totally blown, and then when she re-inserted another one and tried it again, the fuse blew again. Since I do not have a sunroof on my 240, I was wondering if there is someone out there that might be able to give me guidance on helping her figure out the problem, and how to do a step-by-step diagnosis and repair. Any help would be greatly appreciated. Thank you in advance.
1994 940 Sunroof Not Working/Blowing Fuses
Vova585
- Has thanked: 228 times
- Been thanked: 238 times
Step 1- find original wiring diagram.
Step 2. Never put fuse of higher amp than should go there.
Step 3- you likely have wire that is shorted to ground, sunroof motor that is defective, or mechanical obstruction of sunroof slides.
Step 4. Can remove the sunroof motor and try to energize it through the switch-blown fuse=replace motor. If motor works great and fuse in intact- likely your issue is not in wires or motor and rather in mechanical obstruction of sunroof slides. Inspect slides and see if anything stuck there(dirt, mice, stone, coin..) inspect of slides are properly aligned and not bent.
Good luck.
Good luck.
After sometime, I’m finally getting a chance to follow up on my friends sunroof issue, and there’s one more piece that I am hoping will help make the determination of what the problem is here.
When I was able to go over and meet with my friend, I did not realize that, as soon as the ignition switch was powered up, the 30 amp fuse blew immediately; the sunroof switch was not depressed, so it seems like there is something that is shorting before the switch. Does that sound right? Any thoughts?
- 972 Views
Last post by SuperHerman
- 824 Views
Last post by Arwing
- 348 Views
Last post by Caffeind
- 2033 Views
Last post by Jokerz
- 3264 Views
Last post by jimmy57
