Ive sourced the green connectors Volvo use, they are JAE brand IL-AG5 series connectors. Does anyone know what crimp tool to use??
I recycle, re-use salvaged wires and plugs but sometimes have to make them. Note: de-pinning these can be a challenge, there are two small tabs that need to released at the same time. Also the male pin (shown) goes with the Female looking connector, its easy to get male female pins and connectors mixed up
Green electrical connector crimp tool?
- darylrobert
- Year and Model: V70 240 740t xc70
- Has thanked: 6 times
- Been thanked: 44 times
- Has thanked: 987 times
- Been thanked: 1075 times
Perhaps Allied Elecctronics Supply https://www.alliedelectronics.com/srch.html can supply appropriate crimp tool.
crasbe
- Year and Model: 02 S60, 98 V70 (EV)
- Has thanked: 33 times
- Been thanked: 82 times
It is difficult to judge the size of the connectors, but I had good luck with the Engineer crimpers:
https://www.engineertools-jp.com/produc ... ing-pliers
You'll have to measure the width of the crimp connector to select the correct die width and then select the appropriate crimper for the task.
They are single stage, meaning you have to do two operations for the full crimp, but in many cases that is good because you don't have to get a specialized crimping die.
Check out my 3D Printed Parts for Volvo P2 and P80 on Printables
crasbe
Maybe you can also share the exact part numbers here in case someone stumples upon this thread in many years and wants to source the connectors and pins too
- darylrobert
ive had some custom circuit boards made, they make the buttons in white plastic so the light comes through, then paint them grey/blackcrasbe wrote: 25 Aug 2025, 03:56 i checked out your 3D prints, how difficult would it be to print a volvo button, not the whole thing just the moving part pictured?
crasbe
That is probably possible, however it would have to be printed in SLS (powder) due to the high amount of details and the small size.
The print itself is simple and you can even color the part similar to the original one or even print it multi-colored with MJF (Multi-Jet Fusion). The difficult part would be the modelling and personally I don't really have a use for it.
- DavidE7
- Year and Model: 01-07 V70, S60, XC70
- Has thanked: 66 times
- Been thanked: 93 times
I use this Matco crimper for almost everything automotive:
https://www.matcotools.com/catalog/prod ... mping-tool
I purchased this tool for home and for work after seeing it many years ago on a Chrysler mechanic's workbench. If you are very careful, it works for almost every electrical connector brand. There are many copies and other suppliers for the same tool. The key detail is to get the 5 different size crimps with the double curve on the seat side to roll the two crimps over and into the stripped wire bundle.
David E
2001 Moondust V70 2.4 293,000 miles
2001 Nautic Blue V70 2.4 231,000 miles
2004 Nautic Blue XC70 2.5T 258,000 miles
new: 2004 Black Saphire V70R 193,000 miles
2007 Titanium S60 2.5T 277,000 miles
2007 Magic Blue S60 2.5T 233,000 miles
2007 Silver V70 2.4 203,000 miles
P2 Volvos for every person in my family
- darylrobert
thanks i bought a crimping tool that i am 90% happy with. it does a neat job of crimping the wire and insulation at the same time but has a tendency to slightly bend the terminal.
- 1389 Views
Last post by JRL
- 1493 Views
Last post by dm635
- 1334 Views
Last post by Ozark Lee
- 917 Views
Last post by 850TurboTurtle
- 761 Views
Last post by precopster
