What the hell is this?
TJWookiee
Year and Model: 2006 XC70 CC
Has thanked: 7 times
Been thanked: 10 times
Post by TJWookiee »
Hello all, long time,
I recently had some work done on my xc70 so I decided to spruce up the thing that was bugging me since I bought it two years ago, and that's the headlight assemblies. The driver side was cracked and yellow, the passenger side would not allow a low beam to sit in the collar unless you fiddled with it for hours (at least with my hands).
Today I started the work to pull the front bumper and replace the assemblies, and once I'd removed it, I found this inside on the passenger side. Rather than look it up elsewhere, I thought I'd give you all a shot at identifying it. As far as I can tell, the car has been fine without this, so what now?
Vova585
Year and Model: 01v70xc,2016xc70...
Has thanked: 228 times
Been thanked: 238 times
Post by Vova585 »
Unable to open photos
TJWookiee
Post by TJWookiee »
Fixed
Vova585
Post by Vova585 »
I might be wrong on this one, but it looks like headlight washer unit.
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
Vova585 wrote: 24 Aug 2025, 14:11 I might be wrong on this one, but it looks like headlight washer unit.
I'm pretty sure you are right. I was watching a video on a XC90 bumper removal and the guy detached the tube at the yellow clip in order to free the bumper. Should be the same part for most P2's.
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Probably high intensity washer pump.
TJWookiee
Post by TJWookiee »
Given its proximity to the wiper fluid tank, that sounds like it to me. My guess is it was destroyed by a prior owner, the guy I’d bought it from shrugged when I asked him what the nozzles were for and I never looked into it.
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1078 times
Post by volvolugnut »
Looks to me like the remains of a small electric motor.
Has thanked: 1614 times
Been thanked: 4078 times
That is the winner of the crusty of the week, month, possibly year
Vova585
Post by Vova585 »
I can see the confusion with some electrical component. However there is no wiring to there and hose connections in the bumper only suggest headlight washer system(probably the type that extends out of the bumper upon turning high pressure pump ). I think there were 3 styles of headlight washer on v70xc-xc70. Early models (probably 01-03(maybe some early 04) with headlight wipers and hoses attached to them. Later(04-05?) With just spray nozzles(might be wrong here). And later years(06-07) with pup-up design similar to newer P3 chassis.
