Does anyone have a link or a pic with a diagram of where bank one sensor 3 is located and possibly confirm if I can simply use any downstream sensor as a replacement or if I need a specific form of downstream sensor other than specific to volvo xc90...
Hope this makes sense.
Basically hoping to find location on vehicle and part number I need. My code was P0042
XC90 T8 2017 sensor location
Pretribrapper
- Year and Model: 2011 C30 2.0 T5
- Has thanked: 59 times
- Been thanked: 9 times
Pretribrapper
Here are some additional pics but I can't tell which sensor is bank 1 sensor 3. Looks like I have 2 downstream sensors..
Vova585
- Has thanked: 228 times
- Been thanked: 238 times
I went to Volvo oem parts and put 2017xc90 t8 in search. Them emissions system. Search came back for 3 o2 sensors. They were upper, mid and rear. 2 variants of rear sensor based on spec code were offered as well. I assume the rearmost sensor is your sensor 3.
https://volvo.oempartsonline.com/v-2017 ... components
Pretribrapper
Thanks. Looking at the actual catylitic converter, I see it has two o2 sensors attached to it so I am guessing they are both down stream and since the exhaust comes in from the right side of the converter and out the back, I am hoping the green wire o2 sensor on the driver side is actually bank 1 sensor 3. And the one on the passenger side (right) of the converter would be considered bank 1 sensor 2.
Vova585
Not sure.
Would be great to figure out the wires which are responsible for heater element. You would be then able to check resistance between those 2 wires and if OL- totally your customer with broken heater element. Unfortunately it looks like those new sensors are 5 wires and I am not sure what they are(used to be 12v positive and 12 negative for heater, extra ground, signal wire in case of 4 wire sensor).
looks like #6 is your rear sensor.
https://www.volvopartswebstore.com/show ... y_make=865
Pretribrapper
That was awesome thank you. I did replace #6 and part number that worked was 31370964. I did buy on Amazon for $91 but I picked up a couple other ones that say downstream and are compatible but they were not. The connector up at the plug had a stopper in it to prevent the wrong plug. All other ones I used were wrong plug.
Oddly I dont have a #4 that I see anywhere. I only have the #2 I think and they both look to be downstream. No idea where the upstream is.
I did install and reset the CEL but I do still have a P0042 permanent fault for bank 1 sensor 3. I am told I will have to do a few drive cycles to get it to clear if indeed it is corrected
Pretribrapper
Vova585
Sorry, but with amazon or ebay parts you are playing Russian rullet with 1911.
Also it is not true for heater code to be present after code erase and sensor replacement. You may have a readiness monitor not set, but no immediate code. So 2 possibilities- we replaced the wrong sensor, in case we replace the correct sensor and the code is immediately present-wiring prior to the sensor is at fault.
I would vote to buy volvo oem wiring diagram subscription and look which wires are responsible for heater at sensor 3(will give you colors) and then check with 1 apm substitute load at the connector. Check resistance in corresponding wires. So dont throw your old sensor yet.
This sensor you replaced os 4 wires. So prior troubleshooting applies
Pretribrapper
So far looking good and seems to have worked. Thank you all.
Vova585
Well, the scanner data makes sense. Likely your evap and catalytic sensors still not fully tested by ecm to pass. Usually shpuld be 3 drive cycles or more depending on conditions.
So "codes found-0" is the most important thing. The heater element is working in the new sensor. Whether it will work as it should is a different question. I hope you are lucky with this sensor.
- 1162 Views
Last post by Artrebound
- 1057 Views
Last post by mark0006
- 2732 Views
Last post by RickHaleParker
- 17 Replies
- 5712 Views
Last post by jimmy57
- 3551 Views
Last post by gibbi42
